Old 7th February 2015, 02:45 PM
pwacka8 pwacka8 is offline
Default Air Compressor output test
Hello All
Got the dreaded orange and yellow suspension lights on , fronts on the floor.
Took the car apart this morning and tested for leaks , cant find any, i have had the orange light on last week but the suspension stayed up.
Last week i read codes , air leak in system and no default level.
after my investigation today im getting no default level and lower limit reached.
Compressor runs when car is started then the lights come on and lift is greyed out on mmi.
The control block seems to be ok , as i was running output test through vcds i could here the different output air valves operating in turn as i was going through each step.
I suspect the compressor is knackered but i wanted to see if i could measure the output using vcds to see if its output is down.
I believe you can get the output pressure from the measuring blocks some how but im not sure.
Can anyone guide me as to where i can find its current output and also what should it be.
Many thanks in advance as allways.
PWACKA8
2012 4.2TDI SE EXEC
Old 7th February 2015, 03:46 PM
Level control module 34 in vcds
Run output tests go through them in order and when you see accumulator test pay attention to the max pressure.
When I ran mine I saw around 10-11 bar.
Max pressure for the conpressor is 16 bar
I also ran a log file of the pressure sensor and selected the various settings in the mmi and saw as high as 12 bar on the log.
But if you don't know how to log various settings stick with the output tests it's quick and dirty, each test is consecutive so stick with it until you see accumulator test, by the sounds of it, it will most likely fail.
I would order Bagpipeandys ring set so you can rebuild your conpressor.
Old 7th February 2015, 05:02 PM
Ran the output test a couple of times .3.2bar.
I take it thats a little low!
2012 4.2TDI SE EXEC
Old 7th February 2015, 07:31 PM
Johnmed's Avatar
Johnmed Johnmed is offline
Yes that pressure does, unfortunately, seem too low. All the best with a repair. Get your '8 back to where it ought to be.
2007 Mini Cooper S R56
Old 7th February 2015, 10:26 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Get yourself a rebuild kit from bagpippingAndy.
[center]
06 3.0TDI Quattro:
Options:
Old 10th February 2015, 08:35 PM
Guess what im doing tomorow morning
2012 4.2TDI SE EXEC
