Hi Guys,
I'm 6 weeks into A8 ownership and this forum has been a massive help (thanks for all the good tips). I bought my 2006 4.2 TDI with a few known issues, and I'm slowly chipping away at them with the help of forum - but one new issue has left me stumped... My car has xenon lights, next to the xenons are some H7 corning lights, and then inboard from them is a P21W reversing bulb that gets used as a daylight running light. These H7 corning lights just never ever come on - not at speed, reversing, cornering, indicating... I connected VCDS (official Hex+Can version) and cannot connect to the following modules: [29] left light [39] right light [55] headlight range [49] automatic light But I can connect to and retrieve the coding for the following modules: [09] cent. elect. - Coded as 0143121 [4F] cent. electr. II - Coded as 0010101 I wanted to enable showroom mode, but cannot without module 55. Does anyone know what coding I need to be able to activate these corning lights, or am I missing some hardware? Do I have AFS, and should these bulbs actually work? Option xx?xxxx #4 seems to be the only module [09] coding where the P21W's and xenons work as expected. Many Thanks Simon |
Mmi sounds like a strange one that,
If there is no warning lights on the dis for headlights then I suspect someone's coded the car to the most basic lights available so to prevent warnings. You would help others help you by posting a full scan and also try to confirm the headlights fitted to the car.
Del ![]() |
Thanks Delboy,
I ran a scan this morning. I have a hole in the air-con radiator and a duff locking button on the passenger door, so faults on modules [08] and [52] can be ignored (I'll get round to fixing them eventually). VCDS Version: Release 14.10.1 Data version: 20150130 Tuesday,10,February,2015,07:18:43:59507 Chassis Type: 4E (4E0) Scan: 01 02 03 05 06 07 08 09 11 31 15 16 17 18 19 1E 25 34 36 37 38 42 46 47 4F 52 53 56 61 62 67 72 76 77 VIN: WAUZZZ4E86N014230 Mileage: 118880km-73868miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 06-Seat Mem. Pass -- Status: OK 0000 07-Control Head -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: OK 0000 11-Engine II -- Status: OK 0000 31-Engine other -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: Malfunction 0010 18-Aux. Heat -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 1E-Media Player 2 -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 34-Level Control -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: OK 0000 38-Roof Electronics -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: Malfunction 0010 53-Parking Brake -- Status: OK 0000 56-Radio -- Status: OK 0000 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 67-Voice Control -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No SW: 4E1 910 409 A HW: 4E1 907 409 Component: 4.2L V8TDI G000AGMª0080 Revision: --H01--- Serial number: AUX3Z0E9377314 Coding: 0011773 Shop #: WSC 00262 210 89202 VCID: 22411C43FD278231584-8077 No fault code found. Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09E-927-156.lbl Part No SW: 4E1 910 156 P HW: 09E 927 156 B Component: AG6 09E 4,2lTDI RdW 0030 Revision: --H01--- Serial number: 0070989 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 3065E60BA3CB20A1DE0-8065 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC Component: ESP 5.7 allrad H44 0510 Coding: 0008557 Shop #: WSC 02313 000 00000 VCID: 22411C43FD278231584-8077 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 K Component: FBS AUDID3 H08 0160 Revision: 01604808 Serial number: AUX3Z0E9377314 Coding: 0412672 Shop #: WSC 02311 785 00200 VCID: 58B57EABEBFB18E1760-800D Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX No fault code found. ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass Labels: None Part No SW: 4E0 910 760 D HW: 4E0 959 760 B Component: Sitzmemory BFS H02 0010 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063328 Shop #: WSC 00000 785 00200 VCID: 244D1A5BE7338C012A8-8071 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Cannot be reached ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 4E0 910 043 B HW: 4E0 820 043 D Component: KLIMAAUTOMAT 016 0400 Revision: 00000030 Serial number: 00000000079316 Coding: 1071107 Shop #: WSC 02311 785 00200 VCID: 1C3D22BBDF43B4C1928-8049 1 Fault Found: 00819 - High Pressure Sensor (G65) 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 48 Reset counter: 100 Mileage: 113862 km Time Indication: 0 Date: 2014.10.11 Time: 16:33:35 ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4E0-910-279.lbl Part No SW: 4E0 910 279 L HW: 4E0 907 279 L Component: ILM Fahrer H13 0210 Coding: 0143121 Shop #: WSC 00124 012 00001 VCID: 3163E30FA8C129A9D1E-8064 Subsystem 1 - Part No: 4E2 910 113 B Component: Wischer WWS D3 H50 0420 Coding: 00000035 Shop #: WSC 00124 Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB Component: REGENLICHTSENSORH10 0050 Coding: 00139548 Shop #: WSC 00124 No fault code found. ------------------------------------------------------------------------------- Address 11: Engine II Labels: Redir Fail! Part No SW: 4E1 910 409 A HW: 4E1 907 409 Component: 4.2L V8TDI G000AGSª0080 Revision: --H05--- Serial number: AUX3Z0E9377314 Coding: 0011773 Shop #: WSC 00262 210 89202 VCID: 22411C43FD278231584-8077 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4E0-910-655-94.lbl Part No SW: 4E0 910 655 D HW: 4E0 959 655 H Component: Airbag 9.41 H12 3610 Revision: 91H12360 Serial number: 0037P000928B Coding: 0431707 Shop #: WSC 02313 785 00200 VCID: 27570D57960567190FA-8072 Subsystem 1 - Serial number: 63328RB400BBE4CE1 Subsystem 2 - Serial number: 63428RB400BBE43CY Subsystem 3 - Serial number: 63528RB400BBE4F1- Subsystem 4 - Serial number: 63628RB400BBE48F1 Subsystem 5 - Serial number: 63729RB400BD4759W Subsystem 6 - Serial number: 63829RB400BD4748V No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4E0-910-549.lbl Part No SW: 4E0 910 549 HW: 4E0 953 549 Component: Lenksäulenmodul H13 0040 Coding: 0112041 Shop #: WSC 02313 785 00200 VCID: 65CB475FAC89B509FD6-8030 Subsystem 1 - Part No: XXXXXXXXXXX Component: Lenkradmodul H07 0080 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4E0-910-xxx-17.lbl Part No SW: 4E0 910 950 P HW: 4E0 920 950 P Component: KOMBIINSTR. VDO H71 0400 Revision: D02 Serial number: AUDID3EN000463 Coding: 0000403 Shop #: WSC 12345 123 45725 VCID: 3163E30FA8C129A9D1E-8064 1 Fault Found: 02084 - Component Protection 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 00000011 Fault Priority: 1 Fault Frequency: 1 Reset counter: 255 Mileage: 0 km Time Indication: 0 ------------------------------------------------------------------------------- Address 18: Aux. Heat Labels: None Part No SW: 4E0 910 105 A HW: 4E0 815 069 E Component: Heizgeraet H07 0110 Revision: 0000000C Serial number: 00000009006406 Coding: 0000001 Shop #: WSC 00000 000 00000 VCID: 1A3124A3D577CAF1804-804F No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4E0-910-468.lbl Part No SW: 4E0 910 468 B HW: 4E0 907 468 E Component: Gateway H11 0090 Revision: 11 Serial number: 2000305B03808A Coding: FCFEDBDE2B7104 Shop #: WSC 02313 785 00200 VCID: 27570D57960567190FA-8072 No fault code found. ------------------------------------------------------------------------------- Address 1E: Media Player 2 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 111 F HW: 4E0 035 111 A Component: CD-Changer H44 0470 Revision: 00000000 Serial number: AUZ5ZBE8006009 Shop #: WSC 00000 000 00000 VCID: 1C3D22BBDF43B4C1928-8049 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 K Component: FBS AUDID3 H08 0160 Revision: 01604808 Serial number: AUX3Z0E9377314 Coding: 0412672 Shop #: WSC 02311 785 00200 VCID: 58B57EABEBFB18E1760-800D Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX XXXXXXXXXXX ELV XXXX No fault code found. ------------------------------------------------------------------------------- Address 34: Level Control Labels: 4E0-910-553.lbl Part No SW: 4E0 910 553 H HW: 4E0 907 553 F Component: LUFTFDR.-CDC H06 4480 Coding: 0015510 Shop #: WSC 02313 785 00200 VCID: 28550E6B9B1B6861060-807D No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4E0 910 760 D HW: 4E0 959 760 B Component: Sitzmemory FS H02 0010 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063338 Shop #: WSC 00000 785 00200 VCID: 244D1A5BE7338C012A8-8071 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 887 Q HW: 4E0 919 887 D Component: MNS ECE H46 0850 Revision: 00000000 Serial number: 364KU057502942 Shop #: WSC 00000 785 00200 VCID: 3B7FC1277A8DD3F97B2-806E No fault code found. ------------------------------------------------------------------------------- Address 38: Roof Electronics Labels: 4E0-910-135.lbl Part No SW: 4E0 910 135 A HW: 4E0 907 135 A Component: Dachknoten D3 H02 0090 Serial number: 00000529100023 Coding: 0035968 Shop #: WSC 02313 785 00200 VCID: 1D3B2FBFC459BDC9656-8048 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl Part No SW: 4E1 910 802 B HW: 4E2 959 802 B Component: Türsteuer.FS BRM003 0100 Coding: 0028462 Shop #: WSC 02311 785 00200 VCID: 2045164BF32B90214E0-8075 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4E0-910-289.lbl Part No SW: 4E0 910 289 B HW: 4E0 907 289 Component: Komfortgeraet H05 0010 Revision: 00100005 Serial number: W040511020043 Coding: 0004317 Shop #: WSC 02313 785 00200 VCID: 28550E6B9B1B6861060-807D Subsystem 1 - Part No: 4E0 907 719 Component: Neigungssensor H04 0020 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System Labels: 4E0-910-223.lbl Part No SW: 4E0 910 223 J HW: 4E0 035 223 D Component: Amp.-Basis H41 0120 Revision: 00000000 Serial number: 00000057506086 Coding: 0000013 Shop #: WSC 02313 785 00200 VCID: 244D1A5BE7338C012A8-8071 No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: None Part No SW: 4E0 910 280 A HW: 4E0 907 280 A Component: ILM Beifahrer H11 0070 Revision: Serial number: 00000000072676 Coding: 0010101 Shop #: WSC 02313 785 00200 VCID: 1E3928B3C95FA6D17CC-804B No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl Part No SW: 4E1 910 802 B HW: 4E2 959 801 B Component: Türsteuer.BF BRM003 0100 Coding: 0028462 Shop #: WSC 02311 785 00200 VCID: 2045164BF32B90214E0-8075 1 Fault Found: 02126 - Central Locking Button; Exterior Door Handle 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 0 Reset counter: 94 Mileage: 118656 km Time Indication: 0 Date: 2015.02.04 Time: 03:40:36 ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4E0-910-801.clb Part No SW: 4E0 910 801 C HW: 4E0 907 801 A Component: EPB A32C0220 H02 0220 Revision: A32C0220 Coding: 0001031 Shop #: WSC 02313 785 00200 VCID: 1F4715B7CE55AFD977A-804A No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 T HW: 4E0 035 541 L Component: TUNER EU/US/RDW H42 0630 Revision: 00000000 Serial number: 304KU057610948 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 3163E30FA8C129A9D1E-8064 No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4E0-910-181.lbl Part No SW: 4E0 910 181 C HW: 4E0 915 181 C Component: J0644 BEM H12 0550 Revision: 00000000 Serial number: 00000000004422 Shop #: WSC 00778 210 53857 VCID: 2045164BF32B90214E0-8075 Subsystem 1 - Part No: 4E0 915 105 Component: von VA0 YT04155094 Coding: 344530393135313035202056413059543034313535303934 Shop #: WSC 12345 123 45725 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 801 C Component: Türsteuer.HL BRM003 0100 Coding: 0028462 Shop #: WSC 02311 785 00200 VCID: 1E3928B3C95FA6D17CC-804B No fault code found. ------------------------------------------------------------------------------- Address 67: Voice Control Labels: 4E0-910-75x-67.lbl Part No SW: 4E0 910 754 S HW: 4E0 035 753 A Component: SDS 3502 UK H45 0630 Revision: 00000000 Serial number: 00000511030062 Shop #: WSC 12336 024 394758 VCID: 3669D01341AF0E9184C-8063 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 802 C Component: Türsteuer.HR BRM003 0100 Coding: 0028462 Shop #: WSC 02311 785 00200 VCID: 1E3928B3C95FA6D17CC-804B No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4E0-910-283.lbl Part No SW: 4E0 910 283 C HW: 4E0 919 283 C Component: Parkhilfe 8-Kan H12 0030 Revision: 00H12000 Serial number: 08720528501120 Coding: 0201108 Shop #: WSC 02313 785 00200 VCID: 234F1947E23D8B39532-8076 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Labels: 4E0-910-336.lbl Part No SW: 4E0 910 336 F HW: 4E0 862 335 Component: Handyvorb2 H13 0580 Revision: 00000000 Serial number: 00000007589448 Coding: 0010900 Shop #: WSC 02313 785 00200 VCID: 254B075FEC0975093D6-8070 No fault code found. End-------------------------(Elapsed Time: 03:00)-------------------------- I also took a photo of the headlamp unit from the outside to help with identification. It's currently coded as "bi-xenon with Halogen P21W and AFS" ![]() Many Thanks Simon |
Check into 19 - CAN Gateway
Check the Installation list and make sure 55 (and every other module you have) is is ticked The cornering light is 35W H8 bulb) |
Thanks Snapdragon,
I activated module 55 in the CAN Gateway, but VCDS won't connect to it - neither during the full system scan or by connecting directly to the module. I suspect the controller is either dead or not physically installed. Does anyone know where it should be located in the car? I think I need to hunt for it and see what I find. Many Thanks Simon |
I *think* There is a box on the back of each headlight that looks like a xenon ballast but is actually for the cornering light - I *think* it may be the cornering light controller but not sure if it is 55 itself or something between 55 and the bulb as you would only expect one 55 and not two.
The early version of these cornering bulbs (pre facelift) did come on when reversing, the later big grill versions do not. They wont do anything when indicating either iirc. They only work at slow speeds going round corners, moving slowly round a corner out of a driveway for example. I don't recall seeing them work at any other time for a long time, never on big grill cars anyway. The APS swivelling lights system is so much more better and subtle I think Audi sort of stopped the cornering lights from doing much, plus who wants a nasty orange halogen polluting their nice Xenon beam ? ![]()
For parts enquiries and Forum User Administration please contact customer services directly, not me ![]() The Daily Town Car - 2023 Tesla Model Y Performance. Black with Black. Giant ipad screen, huge sunroof, 4 wheel drive, Tow bar, lots of ooomph and made in China, so actually built properly unlike the Californian ones. The Family Wagon - 2018 Tesla Model X. Black, 7 Seats, Towbar, Homelink, Enhanced Auto pilot with Summon and self park, Heated front seats, CCS Charger upgrade, MCU2 Upgrade, Falconwing Doors, Self opening / closing doors, Netflix, Spotify, toys, Air suspension, alcantara roof + lots of other stuff...... The 17 year old Driver Wagon 2015 Skoda Citigo Monte Carlo. Alloys, Power steering, Aircon, Leccy windows, Sat Nav, bluetooth, central locking, cup holders, 59 whole bhp. Million times better than my first car. Well jealous..... The First 20 Audis: 2001 D2 4.2 QS Silver, 1997 D2 S8 Silver, 1999 D2 4.2 Silver, 2002 D2 S8 Dolphin Grey, 2003 C5 RS6 Blue, 1998 D2 S8 Black, 2000 D2 4.2 QS/S8 Ming Blue, 2003 D3 4.2 Ming Blue, 2005 B7 S4 Blue, 2006 D3 3.0 Tdi Black, 1999 D2 4.2 Silver, 2003 D3 4.2 LPG Crystal Blue, 2000 D2 S8 Silver, 2007 3.0 Tdi Q7 Black, 2009 B8 S4 Black, 1998 D2 S8 Agate Grey, 2006 D3 4.2 Tdi Blue, 2006 D3 S8, 2007 Q7 3.0 Tdi, 2006 C6 S6, The Second 20 Audis: 2011 A7 Sline, 2001 A2 1.4 Tdi Black, 2002 A2 1.4 Tdi Silver, 2006 A8 4.2 Tdi Blue, 2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black ![]() 2010 A8 D4 4.2 Silver, 2006 C6 A6 2.7 Tdi Quattro, 2000 D2 4.2 QS/S8 Ming Blue (again), 2008 Q7 4.2 Black, 2009 C6 RS6 Saloon Daytona Grey, 2001 Fully Loaded A2 Tdi, 2006 Avant S6 Black, 2007 VW Caravelle Exec Black (almost an Audi) 2009 TT Roadster Daytona, 2015 Q7 4.2 tdi lava grey, 2002 GmbH D2 demonstrator, 2006 D3 A8 LWB 4.2 Tdi Black Most Recent Audis: 2001 A2 1.4 Tdi Black, 2007 4.2 FSi Q7 ABT Blue, 2016 S5 Coupe Launch model, 2004 S4 B6 Cabriolet, 2016 Q7 Sline White, 2006 Q7 4.2 FSi Black, 2012 Q7 Sline+ 4.2Tdi White, 2008 Blue Audi S8 Everything Else 1989 Subaru Justy, 1986 Vauxhall Cartlton 2.0 GL, 1985 Vauxhall Carlton 2.2 CDi, 1987 Ford Sierra XR4x4, 1983 Vauxhall Senator, 1985 Vauxhall Senator 3.0i, 1997 Polo Saloon, 1997 Peugeot 306 1.9 TDi, Ford Sierra Sapphire 2000E, 1990 Subaru Justy, 2000 Subaru Impreza, 2000 Subaru Impreza RB5, 1993 Range Rover LSE, 2005 VW Bora, 2003 Skoda Superb, 2003 VW Passat V6 4 Motion, 1996 Peugeot 106, 2000 Range Rover 4.0, 2019 Tesla Model 3 Performance |
