I've bought a K&N Panel Air Filter. Before I pester my garage, how easy are they to fit? Any advice?
If it's like other Audi's it should be a 10 minute job as it's a direct replacement. Although I've never done a D2... remove the intake ducting and remove the lid to the air filter box, this should be able to move out of the way a give access to the filter. Remove and replace with the K&N. Reinstall everything.
very easy indeed. just undo the jubilee clips holding the hard pipe from the airbox to the throttle body and the undo the 4 screws holding the top of the airbox on.
lift off lid. remove the original filter and replace with shiny K&N. all you need is a screwdriver really ![]()
2001 S8 D2 ![]() |
Great, I think even I should be able to manage that. The sharp, pointy end of the screwdriver is the bit you hold, right?
AndyCaCa: I noticed your car open and possible S8 rummagings going on last Saturday morning on my way into the city. I very nearly pulled in to say hello but the look on MrsPhil's face when I mentioned it suggested otherwise. |
If it is I wouldn't if I were you. They don't filter very well and also particles of oil get all over the maf screwing it up.
Far better sticking to paper filters IMO
Del ![]() |
I have read thoughts on oiled filters. Some say don't use them, others say don't over oil them and you'll be fine.
There was even a link to k&n's site where they had posted results of the oil in their filter had how it (apparently) stayed in the cotton and didn't clog up the MAF. I think it is an oiled filter - waiting for it to arrive. |
2001 S8 D2 ![]() |
Air filter changed successfully, thanks for the advice.
If you knew how adverse and generally ham-fisted I am with car maintenance and DIY, you'd appreciate how much of an accomplishment this is for me. I reckon that's untapped an extra 200bhp. |
Good stuff, Any change to the induction sound?
When do you chaps fancy having that mini meet we talked about?
Del ![]() |
