Old 12th March 2010, 08:27 AM
How does your wife allow you to spend so much time on this? lol! I'm trying to find time to fit the exhaust and rear brakes, let alone do what you're doing.
I can't wait to see this in the flesh! ... it really does look the business.
Oli
Its a catch 22 at the moment - It wasnt supposed to be this hard, or take this long, but I'm revonating the house in May / June time, which means I have to empty the house, gut all its soft furnishing, plumbing, wiring, bathroom, kitchen etc and we have to have moved out by end of May. The problem is that the house is full of platinum trims at the moment, so I *have* to finish the car, to start the house !!
A of things that make this slightly more possible:
1) I dont need the car, so having it apart for a long time isnt causing me a logistcal problem trying to get to work etc.
2) I'm currently working from home, so I can squeeze in a bit of work on the car over lunch or straight after work.
3) This retrofit is actually a collection of 100+ small 5 minute jobs, so it is actually possible to move things forward in 30 minute windows. I spent 4 evenings cleaning all the interiors in the lounge in front of the telly
I cant wait to see it in the flesh, I do hope it was worth it....
Old 12th March 2010, 06:38 PM
Excellent write up mate.
Old 13th March 2010, 10:02 PM
Talking It all works....
All wiring now complete, including hooking up the power feeds to the distribution board in the boot, and I finally remembered to hook up the red/white wire that is responsible for the headrest retract from the front.....
With all the wiring done, its time to rebuild, but no sense in doing that unless it works, so time to test.....
I checked everything, and it all works exactly as expected:
* Seat adjusts forwards backwards
* Seat adjusts for height
* Seat adjusts for lumbar
* Seat adjusts headrests
* Headrests retract using button in front
* Seat retracts into parked position when rear door opened if button pressed
* Seat heating works for upper and lower seats
(Note I plugged a seatbelt into the buckle to test the seat heating ! - also, the coffee mug is from the relaxing cuppa i sat ane had whilst whizzing backwards and forwards, enjoying my hard work !!)
Also, see this picture with the seat at its maximum reclined position - How comfy does that look...
Now I need a chauffeur
ID:	849   Click image for larger version
Old 13th March 2010, 10:13 PM
Default .... the boomerang solution ....
I have another small problem which its time to tackle.
The center section of the individual seats where all the connectors sit is held in by 2 x 10mm bolts, and a hook that fits over the following alluminium plate:
This is a bit of factory welding, and I'm not personally capable of either :
a) unwelding this bit of plate from the original
b) welding it onto my car
So, heres a different solution:
Running this thin ally plate across the back seat area gives me the same sort of plate to hang the plastic center box on, without any of the hassle of welding..... This is what it will look like once in place:
This will have more than enough strength to hold the lightweight plastic box in place and being so thin, makes it bendable to the exact shape of the floor, so it shouldnt foul anything once fitted....
ID:	851   Click image for larger version
ID:	852   Click image for larger version
Old 13th March 2010, 10:29 PM
Default the rebuild starts...
After confirming all the wiring is good, its time to start refit, so in goes the carpet...
Quickly followed by the center console, new wood trims, rear vents and rear heated set switches, lower B pillar trims and audio / climate
It feels so good to get some bits back in it !
ID:	854   Click image for larger version
ID:	855   Click image for larger version
ID:	856   Click image for larger version
Old 13th March 2010, 10:51 PM
I'm genuinely kind of lost for words, here's me trying to get my head round bypassing the TMC unit to get my RNS E to talk to the can and then you completely just did all; that and just WOW is all I can say and this is the reason they refer to you as the '8' God.. You deserve a medal for this, and when this car, if it ever does comes for sale
Only thing I can say is that I reckon it would look a lot nicer with the later style steering wheel.
Old 13th March 2010, 11:07 PM
Oh dont you worry, I have that covered.... and still a few other tricks up my sleeve yet....
Old 14th March 2010, 10:37 AM
gninnam gninnam is offline
Agree with Amar - WOW
Great job Ian - looking very good so far
Andy.
Current cars:
BMW i4 M-Sport
Peugeot 207 (the sons)
Gone but not forgotten
Old 14th March 2010, 04:44 PM
Mkoneman's Avatar
Mkoneman Mkoneman is offline
looks rubbish, u might as well take it all out and sell it to me ill sling u a fiver for the lot
credit where credit is due and the definitely some credit due here
www.facebook.com/obdworks
full genuine ross-tech vcds
full genuine vag- tacho
Old 14th March 2010, 05:02 PM
Nice one Ian
an amazing job plus a superb write up -
I cant believe you did it all around becoming a dad again!!
