Old 25th August 2011, 08:41 AM
roboblob roboblob is offline
Originally Posted by captain View Post
Update:
- Both front footwell lights do not work either (there aren't any in the back are there?!)
Yip there are ,only come on when the rear door on that side is opened.
Old 25th August 2011, 09:40 AM
captain's Avatar
captain captain is offline
Originally Posted by graynada View Post
If your lights on buzzer doesn't work either I suspect it is the door contact switch that is at fault. On the front doors the switch has 2 contacts, from memory one contact does the door open indicator and the courtesy light, the other the puddle lights and lights on buzzer. I'm not sure about the rear ones.
The door contact switches are part of the door catch. Theoretically they can be changed without changing the entire door catch but I don't think they are listed as seperate items. Either way it is a complete door dismantle to get to
Thank you sir.
The door mirrors are playing up and I think the switch is at fault, so I may well be stripping the door soon anyway! Do you know if the door contact switches can be cleaned up or is it usually just a straight failure?
