As above.
ive removed it with the 4 bolts some time ago. go to put it back, but the 4 bolts dont bite into anything, and i cant get access to where the bolt goes to? someone help? |
Your all as useless as me.
![]() ![]() Unless the retaining nuts have worked loose.. Does the sub cover come off to check?
Yeah mean the cover on the shelf?
yeah that comes off easy to get to the connections which are there. i can even get the sub back into positon, but when i put the bolts in they dont lock into anything. perhaps the retaining nuts are loose, so how do you get them back in place? |
Just checked ETKA there and it doesn't seem to suggest there's anything that could go missing, though it says you should remove the rear shelf
easy removing the rear shelf? is there a pic with it so i can sorta follow the fixings?
