Old 6th May 2012, 01:43 PM
RanjS8 RanjS8 is offline
Default Detach transmission cable
Can someone tell he how to detach the transmission cable from the gearbox please....once that is out I am very close to pulling engine/gearbox out....
Thanks
Ranj
Old 6th May 2012, 03:05 PM
Think it's on Audipages.com
Old 8th May 2012, 06:03 PM
Default Tcu connection
Where the cable was attach to the transmission it is very tight as the passenger downpipe gets it the way...the last thing I wanted to do was try to get downpipe off...so instead I went from the top and removed the centre console and disconnected the cable from the gear stick....
Old 9th May 2012, 09:00 AM
SyncroS8 SyncroS8 is offline
The outer cable sits into a bracket which is held onto the transmission case with two bolts. Just unbolt the bracket.
The inner is a ball/socket setup and you'll need to use something like a long handle trim tool like this...
Then you can just pop the inner cable off the ball which is part of the switch on the transmission.
MG
Old 9th May 2012, 01:28 PM
We dont believe you without photos.....
Old 9th May 2012, 03:19 PM
Just following on from my above post...
You can just see the bracket in this photo for the outer cable.
And you can see it having been detached in this photo showing the cable hanging out of the way.
MG
