Old 7th March 2014, 06:49 PM
If you can spot the connections on the board for the switch, you could always short them together with a bit of wire to see if the board itself is fine. Never had one of these out to point you in a specific area.
Though I am wondering if the issue with the suspension is related..
Old 8th March 2014, 04:55 PM
Hi
Buying new module is a waste of money.
Fixing it is the way to go, it wont be a tiny switch difficult to solder, even a basic iron will do the job.
Would you be able to take it apart and make a picture of the switch??
You will probably find replacement on one of these websites.
http://forum.a8parts.co.uk/showthread.php?t=7265
Old 17th March 2014, 05:11 PM
A8L A8L is offline
Hi All
I have replaced the MMI with once off A8Parts and all is well. Well I have a working 'CAR' button and I can engage jacking mode etc. One thing I did notice is that I cant find the tyre pressure menu in the 'Car' menu.
Also when I finally got the wheel off there is a broken brake pipe which has leaked all over the back of the alloy and the disk thingy!! pics attached.
Is this an easy fix or is it easier to let a garage do it?
I need to concentrate on the parking brake now so tips and advice welcome
anyone need an MMI without working 'CAR' button? Im sure it can be repaired as mentioned earlier.
Not done a scan yet since replacing the MMI but will do tonight...
ID:	7603   Click image for larger version
Old 17th March 2014, 07:11 PM
Not sure on the TMPS issue, but could be needing coded.
If that's the same side as you're getting the failures on, then that makes sense.. Possibly brake fluid in the EPB mechanism.
Old 28th April 2014, 09:17 AM
i have had a similar problem and stripped it right down to the bare circuit board as the sun roof decided it would vomit lashings of water all over the mmi unit .. my whole system is down it wont get past the load up screen when it tries to boot up
did fix the button issue though before and after images
you can see the nasty corrosion on the system that makes the mmi think your pressing 3 buttons at once some times makes it shut down willy nilly and also boot up incorrectly
you can see the crud build up from water ingress or drink spillage
some of this with a soft artists brush did the job
any way it was simple
in my case sadly it did not solve my mmi booting up issue however i am slowly trailing through every optical component in the hope i find whats causing the issue now that my drains are clean at last
hope this helps ... might be too late but could be a sticky for future maybe
Old 28th April 2014, 09:54 AM
VCDS can do an optical loop test for you which may help.. When my PF was getting water in, it was one of the modules behind the glovebox that died.
Old 28th April 2014, 11:18 AM
how do i do that ?
im at a whits end with it now i really am ... i need all the help i can get ive been off work for a month quite ill and cant really afford to start throwing money at guessing whats wrong so if you know how to check the optical loop that would be amazing thank you
Old 28th April 2014, 11:33 AM
ok the errors im getting are this
question is where the hell are they on the car so i can check them
Old 28th April 2014, 11:56 AM
I'd suspect Media Player 2 to start with as it has both electrical and optical faults. That'll be the CD Changer/AMI in the glove box. Looks like the loop gets to it and then fails, though it could be the CAN gateway.
Old 28th April 2014, 12:14 PM
so if it optical error is that likely to be the fiber optic cable rather than the actual unit having failed ?
ive got all the glove box out as we speak and gained access to it all. the cd changer has no lights lit up on it and will not eject or anything... i have put a volt meter on the cable running to the cd changer and there is voltage there but it will not light up ....
