Old 2nd April 2016, 06:47 PM
richardracer richardracer is offline
Default VCDS Level Contol - yellow suspension light stays on
Hello Folks,
I am after some advice from the experts on here please. My D3 S8 has standard suspension, has 160,000 miles and had a new compressor/relay about 60,000 miles ago. I cannot hear any funny noises and had no warning lights when I started.
I wanted to rese my suspension level, since it has been grounding a bit recently and I have just put my summer wheels (20") back on. I had no warning lights on.
I went into VCDS level control module, typed in security code, then worked through channel 1, 2 3, and 4. Channel 4 gave invalid value and I was nor able to set channel 5 to 1 as required. Problem is yellow suspension light came on!
Have gone through the whole calibration procedure about 20 times with no joy.
In the last 3 or 4 attempts, the initiation (suspension to low, suspension to normal, then enter values for channel 1 got stuck at suspension on low, but dash display showed suspension down (white down arrow) and the suspension up (white up arrow) then static (both arrows black).
I also removed the DTC to no avail several times.
Any suggestions what I am doing wrong or what might have happened.
Thanks
Richardracer
2006 Audi S8 V10 Now Sold. Akoya Silver with black/grey leather, standard 20" wheels, hybrid TV, Bang & Olufssen audio, Heated seats front and rear, Dension ipod integration, DAB radio, keyless entry, rear electric blind, bluetooth connection to Apple iphone6S. Started at 60,000 miles end April 12. Now 171,500 miles as at Oct 2017. Now sold to fellow forum member.
Old 2nd April 2016, 09:24 PM
Johnmed's Avatar
Johnmed Johnmed is offline
Hi Richard.
I have calibrated mine maybe 3 times, the last time was a complete nightmare. I couldn't work out why I was having similar errors to you. Very frustrating.
I took a breather. It was a hot day. And tried again, following the instructions I probably got form here, Rosstech TO THE LETTER, and all was well.
I think the driver's door has to be closed,.. You can't be in the car etc etc. First few times I'd had no problems, other that it seemingly taking forever, so I was quite perplexed.
Don't worry too much about the error. Have a read maybe and try again exactly per the instructions.
In future I will do it in a multistory or something, where it's very flat and the weather won't complicate things.
2007 Mini Cooper S R56
