Old 21st June 2010, 10:34 AM
KPS's Avatar
KPS KPS is offline
Default Caliper sticking
Hi guys,
The rear driver side caliper is sticking and causing the wheel to get very hot. Is this something serious and expensive? Also am I safe to drive with it whilst I hopefully get it to AVP which might be a month or so! I've had the discs and pads changed last week only!
Old 21st June 2010, 12:28 PM
I'd say it's serious, but not neccesarily expensive.
A8parts would do you one for a reasonable price, but if you're handy with a spanner, then I'd take it off again and make sure it's not the handbrake mechanism seizing on first, then work the piston back in a couple of times to see if it moves freely.
Old 22nd June 2010, 11:51 AM
KPS's Avatar
KPS KPS is offline
Thanks, i dont know if it is the caliper 100% but a lot more heat coming from that side. I think its the seal more than anything as it had new pads and discs last monday including a MOT so not sure hopefully its something minor but good thing I noticed straight away. I spoke to Ben @ avp and the first thing he said was the seal so getting that ordered and that will the end of that!
