Old 27th July 2018, 11:20 AM
Looks like they're available from about £30 for a cheapo brand, up to about £70-£80 for a Febi Bilstein.
At last a part that costs less than I expected!!
Old 30th July 2018, 06:30 PM
Never done it myself but it looks like a relatively straightforward job. Page 148 here:
http://forum.a8parts.co.uk/attachmen...8&d=1420349882
Assuming your engine is the same as mine Jim (AVP), the part number appears to be 077121350D
http://www.realoem.me/Audi/RDW/A8Q/2...1/121/121095#5
Thanks Mark
It looks quite straightforward, if I had a pin wrench, but why does it say to remove the bumper?
Old 30th July 2018, 06:51 PM
I don't know. Perhaps for better accessibility or to reduce the risk of accidentally damaging the radiator. Is there enough room to get at it without taking the bumper off (my car's still in the garage so I can't check).
I found this, which suggests an alternative to the pin wrench. Seems to be a for a PF A8 but it may help:
http://www.audipages.com/Tech_Articl...n_removal.html
Using a 10mm wrench on one of the four fan pulley bolts to hold the fan still, loosen the large nut holding the fan onto the pulley
Old 3rd May 2019, 12:56 PM
Hi Mikki,
I am getting ready to do this swap. Is this the right part number for the RS6 idler pulley please?
077903341H
No. 26 in the picture.
Thanks!
Name:	RS6 vbelt.JPG
Old 3rd May 2019, 01:39 PM
Yeah that's the one Still available from Audi last time I checked. Mike and I have laser-cut alloy plates for mounting the Spal fan now too if you want one.
Old 3rd May 2019, 06:05 PM
Thanks Mikki, yes please can I have a laser cut aluminium shroud? How much are they?
Damn those pulleys aren't cheap.
Should I get a new bolt for the pulley or reuse the old one?
Old 3rd May 2019, 06:53 PM
£65 odd aren't they? Or have they gone up? I believe the pulley comes complete with the bearing so you shouldn't need to change the bolt.
I'll check with Mike what the mounting plate costs as we need to get a few cut
Old 4th May 2019, 03:29 PM
I saw some prices in $ around 160 which got me worried it will be similar in £. £65 wouldn't be so bad. Should I try the dealer or TPS?
By the way I saw you mentioned the new fan on speed 1 is not quite enough for aircon, did you try both fans on speed 1, what was the amp draw?
I may leave the stock fan on speed 1 and add the new one in parallel.
Old 20th May 2019, 02:56 PM
I may have solved my overheating problem, went to locate the twin thermostat in the radiator to find some numpty left it unplugged!
At least it should be a free fix, hopefully its still working.
I am still going to try the electric fan conversion.
Old 20th May 2019, 03:23 PM
D'oh!
We've ordered more fan surround panels btw. I'll let you know when they land
The new fan is too many amps to run in parallel with the original btw, although you could wire in a separate supply for it. Mine works nicely with it on speed 2 though. When its idling the second fan cuts in and out as needed, with the original running constantly at speed 1.
