Old 20th March 2021, 06:14 PM
I only got a couple of hours on the engine today due to other stuff so stripped off the timing gear and bracketry.
The previous belt change was done with genuine parts but without the locking tools - note the paint spots
With the crank locked, the cams weren't lined up. The timing gear is not very old so it'll all be going back on but this time with the bar.
The crank pulley bolts were replaced last time which is a bonus
The thermostat was in upside down! I wasn't planning on touching this, but the radiator hose was dribbling much more than normal so it needed to be investigated. The little feature at 6 o'clock is a vent which is supposed to allow the system to bleed air through the thermostat when cold (otherwise the stat gets airlocked and won't open). It's supposed to be at 12 o'clock since that's where the air is
After that I got slightly distracted and made a radiator pressure testing tool
Hook up to the tyre inflator and check for leaks...
ID:	25844   Click image for larger version
ID:	25845   Click image for larger version
ID:	25846   Click image for larger version
ID:	25847   Click image for larger version
ID:	25848   Click image for larger version
Old 20th March 2021, 07:13 PM
homer simpson's Avatar
Simple, but genius!
Old 20th March 2021, 09:43 PM
RICKY D's Avatar
RICKY D RICKY D is offline
Oh my!
I’m not impressed with that at all
Yes, the crank pulley bolts were replaced about 4 years back. I don’t know if you remember on my thread when that came off and left me stranded on the motorway. That scenario is what prompted the whole cambelt/water pump etc being replaced back then (poorly by the looks of it )
At least it’s been spotted and will be corrected Thank you Doctor
Loving the radiator testing tool. Genius
Old 21st March 2021, 09:44 PM
Lots done today. Started off cleaning the engine
Unusual to leak from the cam seals so I'll replace both of these
Better
Time for the oil cooler pipe.
The old pipe was broken at both o-ring grooves leaving it in three pieces
Aluminium version fitted
The coolant pipe o-rings, unusually, are both intact
The right hand flange was beginning to get a bit crusty though so just as well both o-rings will be replaced
On to the inlet manifold - the usual oily grit down between the heads and the manifold flange. I cleaned this out as much as possible
before flipping the engine over to take the manifold off, thus ensuring none of the grit gets in to the inlet ports
The inlet manifold is a bit grubby so I'll deal with that in a bit
The usual oily gunge - I'll clean the area above the inlet ports while the engine is upside down
The sump wasn't leaking (also unusual) but it was pretty crusty and the paint was peeling off in many places so this came off to get painted
Not bad inside. Some carbon deposits but mostly clean
Right way up again to clean under the inlet manifold
Much nicer!
Breather plate back in place
The inlet manifold brightened up well with some Elbow Grease
ID:	25857   Click image for larger version
ID:	25858   Click image for larger version
ID:	25859   Click image for larger version
ID:	25860   Click image for larger version
ID:	25861   Click image for larger version
ID:	25862   Click image for larger version
ID:	25863   Click image for larger version
ID:	25864   Click image for larger version
ID:	25865   Click image for larger version
ID:	25867   Click image for larger version
ID:	25868   Click image for larger version
ID:	25869   Click image for larger version
ID:	25870   Click image for larger version
ID:	25871   Click image for larger version
ID:	25872   Click image for larger version
ID:	25873   Click image for larger version
ID:	25874   Click image for larger version
ID:	25875   Click image for larger version
ID:	25877   Click image for larger version
Old 21st March 2021, 10:33 PM
RICKY D's Avatar
It’s such a shame that 95% of this engine beautification won’t be seen. Just as well I can save all these pictures to remind me
Just going back to your previous post about the timing, does that mean the timing is/could be out when the new belt was offered up? I still remember my dad timing a car using the old strobe light gun when I was a kid
Edit: just re read the post. So it looks like the timing was off as the cams weren’t aligned? Can you damage the engine by doing this? I always thought if timing was out you get interference. The rev counter has seen 7k many times since the belt was changed
Old 22nd March 2021, 05:36 AM
Default Nice
"The inlet manifold brightened up well with some Elbow Grease"
Good to see that this can be done. Is this an Actual Product, or just another form of weekend light upper body exercise for you?
Old 22nd March 2021, 06:43 AM
Its an interference engine, but with quite a lot of tolerance to valve timing variation. Its about half a tooth out which won't do it any physical harm, and the ECU can compensate to an extent with the variable cam timing. It just won't run as well as it could.
When I re-fit the belt using the proper tools it will be spot on.
Actual product Elbow Grease Degreaser
Old 22nd March 2021, 11:55 AM
It was mentioned in another thread. Can be bought from Amazon in MJ's link but Asda also sell it and probably other supermarkets
Asda
https://groceries.asda.com/product/c.../1000120228346
Old 23rd March 2021, 09:09 PM
I found these interesting little chunks in the sump on Sunday
Yep, bits of one of the tensioner pads
Caught it just in time!
The gauze was still intact on this one, and the tensioner locked up properly, so the gauze will go in the bin
New pads fitted and the cam & tensioner back in place (spot the slightly cleaner bolts)
New cam seals since the blank was already leaking and the open seal was a bit crusty
A bit of gunge in the cam cover
Cleaned up a bit with new seals
Passenger side done
ID:	25916   Click image for larger version
ID:	25917   Click image for larger version
ID:	25918   Click image for larger version
ID:	25919   Click image for larger version
ID:	25920   Click image for larger version
ID:	25921   Click image for larger version
ID:	25922   Click image for larger version
ID:	25923   Click image for larger version
ID:	25924   Click image for larger version
Old 23rd March 2021, 09:48 PM
RICKY D's Avatar
OH
MY
GOD!
