#251
A long day today with lots done. First job was to recover the other AC hose connector. The first one I did in the bench vice but this one is still attached to the car so needs something of a contrivance to hold it still. The stump of the condenser is clamped to a large axle stand which is tucked in to the chassis leg. There's a wet lump of paper towel wrapped round it so I can heat the nut up with the mapp gas without melting the hose
it takes some heaving to crack the nut loose even after it's heated up The nut is some super-hard grade anodised aluminium and takes the threads from the condenser with it as it comes off. It takes so much force to break it loose that even the hard aluminium is distorted a bit Properly mush in here with the galled up thread from the condenser still stuck in the threads of the nut I made a die set from a couple of steel thread couplers with slots cut in with the grinder. These are progressively wound further and further in to the nuts a little bit at a time and clean up the threads as they go I keep going until I can thread the coupler in completely by hand Internal threads cleaned up On to the arches. Left side first Better Left engine bay also cleaned Driver's side arch The fuel pipe clamp was rusted to dust Apply all purpose cleaner and agitate, then rinse off with water Amazing tar contamination. I've never seen one this bad before the left side had a lot of tar, but nothing like as much as this Cleaned up with Gtechniq tar remover and the other side of the bay also done. I'll treat all this with sealant tomorrow |
#252
Great work as always,your commitment is second to none ,as a matter of interest what did you paint the manifold with as I assume there would be an awful amount of heat in there
With Bang & Olufsen Advanced Sound System, Advanced Parking System, TV Analog/ Digital, Rear/Back Window blinds, Front and rear heated seats, Alcantara Roof, Extended leather Pack 2, Extended Aluminium pack, Carbon and Aluminium trim packs, RSE, PS2. Daily driver Audi A8 d4 2014 phantom black 3.0 tdi Previously owned Audi 80 1986 1.8 white Audi 80 1990 2.0 red Audi A4 1996 1.9 tdi green Audi A6 1.9 tdi 2000 blue Audi tt 225 2000 silver Audi s8 d2 2002 fe grey Audi a8 4.0 tdi d3 2006 black Audi a8 3.0 tdi d3 2010 black |
#253
Standard acrylic spray paint. The manifold doesn't get particularly hot since its mostly full of incoming cold air, and the only heat sources are conduction through the mounting flange and general heat of the engine bay. It doesn't get any hotter that the bodywork in direct sunlight - 60-70c probably.
#254
Nice work as always MJ. The car is starting to look really good. I just love a clean engine bay
#255
Will there be a sticker on the dash warning the car must be driven in dry weather only? A clean motor and bay is always a good pre-requisite
![]() Also, what is the blue thingie top right of the picture, top rear nearside arch? To do with AC?
Paul Gosport UK ________________________ Polestar 2 Long Range Audi S8 2002 https://forum.a8parts.co.uk//showthread.php?t=16187 Honda Jazz Harley Low Rider 107 Stage 2 Harley Sportster 1200 |
#256
It'd stay that clean for about ten minutes round here!
The blue pod is a vacuum reservoir for the inlet manifold. There's usually one on the other side as well but it was removed to make access for dent removal a little while back. I wonder what the term is for storing a vacuum, since you can't really store an absence of something? Anyway, they store an absence of air for if the ecu wants to activate the manifold after or during high throttle openings when the engine isn't naturally making much vacuum ![]() |
#257
What about the underbody sealer in 9th pic, is this fresh paint or just super cleaned?
#258
Just cleaned
#259
Loving this thread ![]()
#260
Rivnut time. Two studs on the heat shields are missing - one corroded away, and one broken off when the gearbox was refurbished, as they always seem to be.
Grind a divot in the stump Pilot drill then drill to size for an M6 rivnut Rivnuts inserted Temporarily bolted in place while I wait for the new fasteners to arrive Another one above the steering rack. This is normally a stud, but with the tie rods attached it is impossible to remove the rack with it in place so I convert it to a rivnut and another one in the usual spot to hold the starter cables This disgraceful mess was also done when the gearbox was removed it should look like this better cleaned up The brake pipes on the left are quite crusty. This looks bad, but its just salt from the galvansing underneath the plastic. The steel pipes are still perfectly sound Scrape off all the salt and loose plastic coating the clean up with scotchbrite on the rotary tool and paint with rustoleum using a cotton bud as a tiny paint roller Good as new ![]() The fuel pipe clips will sit overnight in Evaporust Quote:
![]() ![]() Yeah, I cleaned the floorpan ![]() Engine bay all done and treated with sealant |
