Old 14th February 2022, 09:48 AM
I
Will there be a sticker on the dash warning the car must be driven in dry weather only? A clean motor and bay is always a good pre-requisite
Also, what is the blue thingie top right of the picture, top rear nearside arch? To do with AC?
Paul
Gosport UK
________________________
Polestar 2 Long Range
Honda Jazz
Harley Low Rider 107 Stage 2
Harley Sportster 1200
Old 14th February 2022, 10:40 AM
It'd stay that clean for about ten minutes round here!
The blue pod is a vacuum reservoir for the inlet manifold. There's usually one on the other side as well but it was removed to make access for dent removal a little while back. I wonder what the term is for storing a vacuum, since you can't really store an absence of something? Anyway, they store an absence of air for if the ecu wants to activate the manifold after or during high throttle openings when the engine isn't naturally making much vacuum
Old 14th February 2022, 11:53 AM
Ronin Ronin is offline
What about the underbody sealer in 9th pic, is this fresh paint or just super cleaned?
Old 14th February 2022, 12:38 PM
Just cleaned
Old 14th February 2022, 08:02 PM
Rivnut time. Two studs on the heat shields are missing - one corroded away, and one broken off when the gearbox was refurbished, as they always seem to be.
Grind a divot in the stump
Pilot drill then drill to size for an M6 rivnut
Rivnuts inserted
Temporarily bolted in place while I wait for the new fasteners to arrive
Another one above the steering rack. This is normally a stud, but with the tie rods attached it is impossible to remove the rack with it in place so I convert it to a rivnut
and another one in the usual spot to hold the starter cables
This disgraceful mess was also done when the gearbox was removed
it should look like this
better
cleaned up
The brake pipes on the left are quite crusty. This looks bad, but its just salt from the galvansing underneath the plastic. The steel pipes are still perfectly sound
Scrape off all the salt and loose plastic coating
the clean up with scotchbrite on the rotary tool
and paint with rustoleum using a cotton bud as a tiny paint roller
Good as new
The fuel pipe clips will sit overnight in Evaporust
There is now You had to poke the OCD tiger
Yeah, I cleaned the floorpan
Engine bay all done and treated with sealant
ID:	27866   Click image for larger version
ID:	27867   Click image for larger version
ID:	27868   Click image for larger version
ID:	27869   Click image for larger version
ID:	27870   Click image for larger version
ID:	27871   Click image for larger version
ID:	27872   Click image for larger version
ID:	27873   Click image for larger version
ID:	27874   Click image for larger version
ID:	27876   Click image for larger version
ID:	27877   Click image for larger version
ID:	27878   Click image for larger version
ID:	27879   Click image for larger version
ID:	27880   Click image for larger version
ID:	27881   Click image for larger version
ID:	27882   Click image for larger version
ID:	27883   Click image for larger version
ID:	27884   Click image for larger version
ID:	27886   Click image for larger version
ID:	27887   Click image for larger version
ID:	27888   Click image for larger version
ID:	27889   Click image for larger version
ID:	27890   Click image for larger version
ID:	27891   Click image for larger version
Old 14th February 2022, 08:22 PM
Excellent work!
If you were to use rivnuts on the rear heatshield, would you have to remove the carpet to drill through just the floor and not damage the carpet?
Old 14th February 2022, 08:42 PM
I will be using rivnuts on those yes, but I won't be taking the carpet out. I'll just use a stop on the drill bit.
Old 15th February 2022, 10:52 AM
Does this mean that from now on any visit to the D2 doctor you have to make sure your bottom is cleaned?
Any specific cleaning guide to pass on to the detailer?
Paul
Gosport UK
Honda Jazz
Old 15th February 2022, 11:12 AM
Sparkling
I'll be coating the floor with the same sealant I use in the engine bay, so in theory it should remain relatively hydrophobic for a while and be easy to wash off any muck. That certainly worked on my Mum's Beetle cabrio which I did back in 2019, although that doesn't do many miles.
It certainly makes it a nicer place to work when its nice and clean underneath
Old 14th February 2022, 07:49 PM
Negative pressure vessel
Loving this thread
