Old 13th February 2022, 07:33 PM
A long day today with lots done. First job was to recover the other AC hose connector. The first one I did in the bench vice but this one is still attached to the car so needs something of a contrivance to hold it still. The stump of the condenser is clamped to a large axle stand which is tucked in to the chassis leg. There's a wet lump of paper towel wrapped round it so I can heat the nut up with the mapp gas without melting the hose
it takes some heaving to crack the nut loose even after it's heated up
The nut is some super-hard grade anodised aluminium and takes the threads from the condenser with it as it comes off. It takes so much force to break it loose that even the hard aluminium is distorted a bit
Properly mush in here with the galled up thread from the condenser still stuck in the threads of the nut
I made a die set from a couple of steel thread couplers with slots cut in with the grinder. These are progressively wound further and further in to the nuts a little bit at a time and clean up the threads as they go
I keep going until I can thread the coupler in completely by hand
Internal threads cleaned up
On to the arches. Left side first
Better
Left engine bay also cleaned
Driver's side arch
The fuel pipe clamp was rusted to dust
Apply all purpose cleaner and agitate, then rinse off with water
Amazing tar contamination. I've never seen one this bad before
the left side had a lot of tar, but nothing like as much as this
Cleaned up with Gtechniq tar remover
and the other side of the bay also done. I'll treat all this with sealant tomorrow
ID:	27845   Click image for larger version
ID:	27846   Click image for larger version
ID:	27847   Click image for larger version
ID:	27848   Click image for larger version
ID:	27849   Click image for larger version
ID:	27850   Click image for larger version
ID:	27851   Click image for larger version
ID:	27852   Click image for larger version
ID:	27853   Click image for larger version
ID:	27855   Click image for larger version
ID:	27856   Click image for larger version
ID:	27857   Click image for larger version
ID:	27858   Click image for larger version
ID:	27859   Click image for larger version
ID:	27860   Click image for larger version
ID:	27861   Click image for larger version
ID:	27862   Click image for larger version
ID:	27863   Click image for larger version
Old 13th February 2022, 07:53 PM
S81 S81 is offline
Great work as always,your commitment is second to none ,as a matter of interest what did you paint the manifold with as I assume there would be an awful amount of heat in there
Daily driver
Previously owned
Audi 80 1986 1.8 white
Audi 80 1990 2.0 red
Audi A4 1996 1.9 tdi green
Audi A6 1.9 tdi 2000 blue
Audi tt 225 2000 silver
Audi s8 d2 2002 fe grey
Audi a8 4.0 tdi d3 2006 black
Audi a8 3.0 tdi d3 2010 black
Old 13th February 2022, 08:38 PM
Standard acrylic spray paint. The manifold doesn't get particularly hot since its mostly full of incoming cold air, and the only heat sources are conduction through the mounting flange and general heat of the engine bay. It doesn't get any hotter that the bodywork in direct sunlight - 60-70c probably.
Old 14th February 2022, 06:55 AM
Nice work as always MJ. The car is starting to look really good. I just love a clean engine bay
Old 14th February 2022, 09:48 AM
I
Will there be a sticker on the dash warning the car must be driven in dry weather only? A clean motor and bay is always a good pre-requisite
Also, what is the blue thingie top right of the picture, top rear nearside arch? To do with AC?
Paul
Gosport UK
________________________
Polestar 2 Long Range
Honda Jazz
Harley Low Rider 107 Stage 2
Harley Sportster 1200
Old 14th February 2022, 10:40 AM
It'd stay that clean for about ten minutes round here!
The blue pod is a vacuum reservoir for the inlet manifold. There's usually one on the other side as well but it was removed to make access for dent removal a little while back. I wonder what the term is for storing a vacuum, since you can't really store an absence of something? Anyway, they store an absence of air for if the ecu wants to activate the manifold after or during high throttle openings when the engine isn't naturally making much vacuum
Old 14th February 2022, 11:53 AM
Ronin Ronin is offline
What about the underbody sealer in 9th pic, is this fresh paint or just super cleaned?
Old 14th February 2022, 12:38 PM
Just cleaned
Old 14th February 2022, 07:49 PM
Negative pressure vessel
Loving this thread
Old 14th February 2022, 08:02 PM
Rivnut time. Two studs on the heat shields are missing - one corroded away, and one broken off when the gearbox was refurbished, as they always seem to be.
Grind a divot in the stump
Pilot drill then drill to size for an M6 rivnut
Rivnuts inserted
Temporarily bolted in place while I wait for the new fasteners to arrive
Another one above the steering rack. This is normally a stud, but with the tie rods attached it is impossible to remove the rack with it in place so I convert it to a rivnut
and another one in the usual spot to hold the starter cables
This disgraceful mess was also done when the gearbox was removed
it should look like this
better
cleaned up
The brake pipes on the left are quite crusty. This looks bad, but its just salt from the galvansing underneath the plastic. The steel pipes are still perfectly sound
Scrape off all the salt and loose plastic coating
the clean up with scotchbrite on the rotary tool
and paint with rustoleum using a cotton bud as a tiny paint roller
Good as new
The fuel pipe clips will sit overnight in Evaporust
There is now You had to poke the OCD tiger
Yeah, I cleaned the floorpan
Engine bay all done and treated with sealant
ID:	27866   Click image for larger version
ID:	27867   Click image for larger version
ID:	27868   Click image for larger version
ID:	27869   Click image for larger version
ID:	27870   Click image for larger version
ID:	27871   Click image for larger version
ID:	27872   Click image for larger version
ID:	27873   Click image for larger version
ID:	27874   Click image for larger version
ID:	27876   Click image for larger version
ID:	27877   Click image for larger version
ID:	27878   Click image for larger version
ID:	27879   Click image for larger version
ID:	27880   Click image for larger version
ID:	27881   Click image for larger version
ID:	27882   Click image for larger version
ID:	27883   Click image for larger version
ID:	27884   Click image for larger version
ID:	27886   Click image for larger version
ID:	27887   Click image for larger version
ID:	27888   Click image for larger version
ID:	27889   Click image for larger version
ID:	27890   Click image for larger version
ID:	27891   Click image for larger version
