  #30
Old 10th January 2022, 07:33 PM
Getting the gearbox ready for its service. As it has been 'recently' refurbished, I don't plan on draining the diffs - the oil in them is nice and clean. However, if I flip it over to do the sump and filter all the oil will dribble out of the vents. That is solved with some 3d printed polyurethane bungs
The torque converter was rebuilt by JP Automatics in Bristol, which is a good sign
After sitting in Evaporust overnight, the power steering pump relinquished the pulley with a little help from the bearing puller and the mapp torch
The hub cleaned up nicely
A little corrosion on the pulley is easily dealt with
Engine and gearbox ready for shenanigans
ID:	27635   Click image for larger version
ID:	27636   Click image for larger version
ID:	27637   Click image for larger version
ID:	27638   Click image for larger version
ID:	27639   Click image for larger version
