It didn't occur to me to do it any other way tbh, since I had an OE harness to use, and there's no reverse light signal up in the roof. The headlining was already down from doing the dents so actually it was pretty easy.
The headlining is held in above the rear doors with some extremely fragile clips which appear to be made from some sort of resin. Its almost impossible to get them out without them either shattering, or breaking off the headlining. So of course I 3D printed some new ones. Hot-glued on to the headlining Fitting a headlining single-handed is not the easiest of tasks so I contrived an arrangement to hold the front of it up in the air while I put the rear up The printed clips worked perfectly Headlining in place I had a dig through my oddly plentiful collection of platinum bits and picked out the best bits, and then cleaned them all up which is considerably easier on the bench than in the car! New single-use pillar trim clips Driver's side A-pillar back in place. I replaced the door seal too since that was quite scruffy. |
Amazing work as ever.
![]() Personally, having fitted auto-dim mirrors in a number of cars over the years I find the "un-dim in reverse" totally irrelevant so ignored it every time, the last being on my PF S8, but serious brownie points for doing it right! ![]() I guess the nearest reverse signal is the long (red/blue?) wire that runs all the way from (I don't know where) via the F125 then the RNS to the back of the car, so yes hardly convenient. ![]() As for dimming mirrors being difficult to get, is it the units, wiring (surely you can fix that) or the actual mirrors glass that is the problem? My current S8 was fitted with them at the factory but by the time I got it had standard external glass. I found a nearside glass fairly easily but my drivers side is actually a US nearside one, complete with inane printed warnings! ![]()
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 2nd January 2022 at 08:37 PM. |
Cars... '93 Audi Coupe 2.0 Alpine White (sold) '99 Audi S4 Merlin Purple - K04 upgrade to 412hp (sold) '00 Audi S8 Agate Grey (Sold ![]() '11 Audi Q7 4.2tdi Unknown Red (Classic Red Pearl Effect - thanks MJ) |
I hope the heater for your workshop is still working this week!
Autos Autos everywhere... (1) 2015 Tesla Model S: (was 85D, now 90D ![]() ![]() (2) 2002 D2 S8 Final Edition: Bulletproof and faultless: Brilliant Black with Extended (Red!) Leather. Three-times winner of Best D2 1st prize (3) 1997 Fiat Coupe 20v Turbo: Scots (! ![]() (4) 2010 Fiat Panda 100HP. White Pandamonium (Final Edition!!). Pure old-fashioned 6-speed go-karting. |
I haven't had to use it yet this winter. Today is the first day the temperature is much below 10c (3 this morning), and I'm busy enough not to notice at the moment. It may be needed if it stays like this, but I have plenty of kerosene if it is
Headlining etc looking spotless!!
![]() Is there a guide to what cleaners to use and how to clean these? also can they be done in situ? My '8's headlining is a little grubby in places and I just dont have the time / faith in my own abilities to remove it....
Paul Gosport UK ________________________ Polestar 2 Long Range Audi S8 2002 https://forum.a8parts.co.uk//showthread.php?t=16187 Honda Jazz Harley Low Rider 107 Stage 2 Harley Sportster 1200 |
I use Quantum upholstery cleaner from TPS, partly because it smells of bakewell tart instead of vomit and hospitals like most of them do, but also because its very effective.
For the actual headlining I'll mist it on and wipe off very gently with a freshly washed microfibre as the foam in the headlining is quite delicate so any sort of pressure will ruin it. The pillar trims are much more robust and can take some light agitation with a nailbrush and then a wipe with a microfibre will lift most dirt out. Again, mist it on rather than soaking as the glue could come undone. Same goes for the rear deck. Its obviously much easier on the bench, but I wouldn't take one out just to clean it as there is a high risk of damage. |
I gave all the leather another coat of leather care and then started putting it back in the car
While the rear door cards were off I swapped the triangles for some nicer ones Mike came over today and helped me finish off the interior Now thats all done, time for the mechanical stuff! Not updated the totals for a bit: 240 hours, £3412 Parts used: PS hoses (refurb, £200) PS hose brackets (used) NSF upper rear arm (used) NSF lower rear arm (used) NSF wheel bearing (used) CV boot (£12) Suspension brace (used) Boot lid (£150) FE wheels (£500) Window motor (£50) Headlight level arm joints (£15) Radiator (£300) Belt idlers (used) Accessory belt & idlers (used) Snub mount (£60) Air filter (£6) Wiper mechanism & motor (£120) Air box trim (£10) Intake duct (£10) Bumper (£200) F125 (£1) Exhaust clamps (£30) Boot grommets (£15) Brake fluid (£20) Wiper trim (£50) Platinum carpet (£25) Central locking pump (£60) Lateral Acceleration Sensor (£20) N/S seat belt (£18) Potions and microfibres (£120) Wiper blades (£30) Bosch S3 019 battery (£85) Bosch lambda sensors 2x (£120) Parking sensors 2x (£40) SAI removal plates + map (£65) Fuel pump (£140) Paint correction (£600) Dent removal (£180) Headlining & interior trim (used) Aluminium roof trim 2x (£160) |
Natty little hole under the passenger armrest
That's for the phone cable which plugs in to the block under the armrests. Or, used to anyway. Not a lot of use these days, since most modern phones don't fit in to the armrests.
