#221
£30 tensioner is paying off ok for me for now.... if it fails I'll start a thread about it
#222
Bank 1 this evening
The gauze has split on this one and the middle has gone through the tensioner hence the startup rattle Cam cover cleaned and new gasket installed Sealant in the corners Back on, two new tensioners installed ![]() Thats all the internal work done on the engine The replacement manifold is almost ready for paint. Serendipitously, this is from my grey S8's original engine so I know there's only 113K miles on it. I know this one is from my engine because the previous owner had a can of orange paint, and for some reason painted random bits of hardware and engine parts with it ![]() Since the injector rail is off for paint I will replace all the injector filters and seals |
#223
I'm so glad I took your advice removed my filters on the tensioners now
#224
Autos Autos everywhere... (1) 2015 Tesla Model S: (was 85D, now 90D ![]() ![]() (2) 2002 D2 S8 Final Edition: Bulletproof and faultless: Brilliant Black with Extended (Red!) Leather. Three-times winner of Best D2 1st prize (3) 1997 Fiat Coupe 20v Turbo: Scots (! ![]() (4) 2010 Fiat Panda 100HP. White Pandamonium (Final Edition!!). Pure old-fashioned 6-speed go-karting. |
#225
#226
You really don't want to be mixing PF and FL drivetrains - trust me on that one! I do have an FL 4.2 on the shelf though
#227
Injectors tonight.
Having struggled to get the filters out of the PF injectors, I made a tool ![]() Then a trim removal tool can be used to lever against the tool and pop the filter out thus: All the filters removed. They are actually all clean and in perfect order, but I didn't know that until I took them out ![]() At this point I was thwarted as the new filters are a slightly different size so I had to stop. I need to query this with the supplier tomorrow before proceeding, so I finished off prepping the manifold for paint which will hopefully go on tomorrow. |
#228
https://www.partsworldperformance.co...ngine-19369333 With a 5HP19 that will work ![]() ![]() ![]()
Paul Gosport UK ________________________ Polestar 2 Long Range Audi S8 2002 https://forum.a8parts.co.uk//showthread.php?t=16187 Honda Jazz Harley Low Rider 107 Stage 2 Harley Sportster 1200 |
#229
Actually I do know a chap who could build a 5HP to take that beast. Only problem is, the crank pulley would be roughly where the number plate lives
#230
