Closed Thread
Old 21st January 2009, 05:53 PM
Default Body and Exterior Repair Sticky
Here we will post links to Body and Exterior related solutions. This post will be edited by an Administrator when a new solution is found either within this forum or elsewhere on the Interweb.
To Start the Ball Rolling here are some classic links from Paul W's Audipages. This site can't be recommended enough as a gold mine of information about you 8.
BODYWORK
Boot Lid full of water - Simon Wallwork
Fog Light (FL) Grills - Tip to stop them being lost - Oli18
Pre Facelift A8 D2 Paint Codes & Names - Ian@a8parts
Removing the Bumper and Front End for Maintenance - Audipages
Wing Mirror ECU Replacement - General Git
Windscreen Trim Removal - Notorious
Wing mirror reverse tilt problem cured. - Notorious
Door lower Trim removal - Adrian E
FL Trim Refurbishment with Powder coating - Notorious
D2 body stud repair - MikkiJayne
Help with Undertray Clips and Arch Liner Clips - HPSauce & Others
Remember, if you find a solution to a problem you've had or others have posted on the web let an Admin know (PM or email) and we will add it to this sticky.
Old 2nd March 2009, 05:56 PM
Sticky Updated.
Closed Thread
