Old 24th May 2011, 10:03 PM
AndrewGray AndrewGray is offline
Default Transmission Casing Diagrams
Hi,
I was wondering if someone could send me some diagrams? I am working behind the cup that the front driveshaft bolts into.
I have removed the cup and I am looking to remove the casing. I believe that all I need to do is remove the bolts most outer on the casing shown in the following picture:
I am wanting to look at an exploded diagram first before doing this and make sure that it is going to come apart how I think it is.
The car is a 96 4.2 D2
Thanks
Andrew
Old 25th May 2011, 04:39 PM
Andrew,
What is it your trying to do? If it's the output seal change then you don't need to remove the casing. This may be of some use.
Old 30th May 2011, 01:49 PM
Andrew,
Hi, I have done the output seal change but I am needing to remove the casing to gain more access for another issue.
Any chance you could sort me out with some diagrams so I can see how to remove it?
Thanks
Andrew
Old 30th May 2011, 04:18 PM
E-mail sent.
Old 30th May 2011, 10:54 PM
thanks!
