Old 24th February 2012, 06:15 AM
Default Should I be worried?
On starting my S8 on a cold morning, there is a very brief metallic rattle that sounds a bit like a chain. It only lasts a second or less. Should I be worried? Perhaps the oil pump not up to scratch?
Old 24th February 2012, 06:27 AM
Take a look at THIS thread Jim, many of us get some noise like this on initial start up. There are other links to pistonheads threads worth reading including an Audi Service Bulletin HERE
Name:	Audi Rattle.jpg
Old 24th February 2012, 08:16 AM
Nollywood's Avatar
I had that noise a few times starting from cold just before winter really set in. I now do an oil and filter change every three thousand miles, and have never had any more start-up rattle, even with ambient temperature at -6 degrees.
Old 24th February 2012, 10:46 AM
sarg sarg is offline
I had that noise, death rattle I called it, for 4 years, it never got any better or worse
2002 Mark's D2 S8 FE
2000 FL D2 4.2 QS - SOLD 2011
Old 24th February 2012, 03:38 PM
B@fink B@fink is offline
odd that the TSB has 2.8 v6's listed in both the A4 and A6 as potentially having this issue but the A8 version is ignored....presumably edited for the US market? I haven't heard a peep out of mine however. Lucky me.
Old 24th February 2012, 05:20 PM
nothing to worry about Jim, mine has done it from day I got it, if you remember I had the oil pump changed and it made it a bit better for a while, and its also better just after an oil change, the Audi Tech bulletin and this thread puts your mind at ease, with hind sight I probably wouldnt have bothered getting the oil pump replaced on mine but apart from a dent in the wallet can only be a good for the engine I guess.
Old 25th February 2012, 06:00 AM
Thanks yet again guys!
Good to know it's not a problem
Old 29th February 2012, 09:25 PM
Mine has had it for a year and a half too, goes away with a new oil change for a month or two, then comes back.
I recently saw on a porche forum (I think it was 986) they use pretty much the same part, but they say Porsche updated the variator it with springs to keep the tension until oil pressure takes over. Shame Audi didnt do that too.
Old 29th February 2012, 11:45 PM
I have a 986 Boxster, definitely doesn't make that noise
