Old 21st December 2009, 07:38 PM
carrotchomper carrotchomper is offline
Default A8 V8- VERY tappety on cold mornings.
Any ideas? There is always a momentary slightly more rattly engine sound when I start up, presumably before the oil has circulated. However at the moment, and particularly today, the engine was noticeably louder for c.5secs.
Any ideas- Right/wrong oil etc? Or should I be checking the oil pump? There are no warning lights coming up and AFAIK the oil level is fine, although I'll check it in the morning (Was fine a couple of weeks ago and didn't seem to have used any for months up to then)
It sounds like a bag of spanners. Not for long. But I'm worried.
Old 21st December 2009, 08:47 PM
B@fink B@fink is offline
I Hope it's nothing serious! without a pressure gauge i don't know how you'd check oil pump operation but if you don't know what grade oil is in it, swap it out for the correct grade, better safe than sorry! Make sure you also use a quality filter, some cheap pattern filters don't have anti return valves in them and oil can drain back meaning you get a moment of chatter until the oil gets back where it's needed. It's really cold and if the oil is too thick it will only get thicker in cold weather and take longer to get about.
Old 22nd December 2009, 06:55 AM
It is normal for a short spell of tappet sound as the oil pressure builds up and this will be made worse on very cold mornings. It would also be made worse if you were running the wrong oil. The owners handbook gives oil grades based on average tempretures.
Old 22nd December 2009, 05:54 PM
Thanks for that. It's a nasty sound when it's really cold The Barge is due an oil change fairly soon anyway so I will make sure the proper grade goes in this time- If in fact it was wrong last time
Old 24th December 2009, 07:31 PM
Oli18's Avatar
Oli18 Oli18 is offline
i had this on my FL 3.7 QS when i still had it...i wouldn't worry about it...it's just the oil getting around. Like Mike says, make sure to check the oil type just to be sure though
Audi A8/S8 D2 Flickr Group
Old 25th December 2009, 03:47 AM
the following threads might help reassure - especially the first - read the service bulliten attachment posted by mike
http://www.tyresmoke.net/forum/audi-...-start-up.html
http://www.tyresmoke.net/forum/audi-...y-running.html
http://www.tyresmoke.net/forum/audi-...old-start.html
Old 26th December 2009, 09:33 AM
Useful stuff
Thanks for that . It's difficult to explain but it's a horrible noise- Not even tapping as such, just a bit of a screech which goes away very quickly. The above threads do somewhat make me feel better though.
I have started to think that it's actually not engine related, the engine sounds fine "Underneath"- Could this be anything to do with the gearbox- Low oil or something? Coincidentally it is starting to play up a little- Nothing major, just a few slightly rough changes and a bit of hesitation...
You'll need to put a new "spotted" up soon though- I'm taking the OH's yellow Mini One to and from work for the time being. I don't think the A8 likes the twice-daily run from cold, it's only 2-3 miles to work through heavy traffic. Last tank of fuel did 165 miles on £70...
Having said that, I was due to take it to work on the snowy morning. Glad I took the A8- Only me and a few 4x4s braving it, lesser cars stuck everywhere- I love quattro!
Old 26th December 2009, 09:36 AM
Screech on startup and dodgy shifts sounds like you need a fluid and filter change on the gearbox...
I assume it's a 5-speed?
Old 26th December 2009, 10:21 AM
Wot he said. If you head said screech at start up the Transmission followed by AC compressor bearings would have been my suggestions. You can bowl out the AC compressor by switching to Econ while the noise is happening. If the noise stops it the AC Compressor.
With the transmission the noise goes away as the box warms up.
Old 26th December 2009, 04:39 PM
Thanks- The noise is very transient- Stops within literally a couple of seconds. I will try the A/C switch if I can within the time it happens. In that case, still likely to be gearbox? If so, how much is a fluid/filter change?
PS. Yes- It's a five speed
