Old 7th March 2012, 06:14 AM
graynada graynada is offline
Originally Posted by sundayrider View Post
Start with the key in, but the ignition turned OFF
Press and hold the 0,0 button, while turning the ignition on (position 2)
Release the 0,0 button
"SERVICE" should now appear on the display
Press and hold the 0,0 button until the display shows "SERVICE IN xxxx Miles / Kilometres"
Release the 0,0 button, then turn off the ignition
I think there maybe a slightly different version but this worked for me.
This doesn't work for me on my '96 D2, I just end up with a reset trip odometer
Does anyone know if there is a procedure for do it without VCDS on a car of my vintage?
Old 7th March 2012, 06:38 AM
Don't think so mate, we have a vintage when Audi were not playing fair.
I'll have my laptop next week if you want to meet up for a reset
Old 7th March 2012, 07:03 AM
Thanks, I may take you up on that offer
Old 24th March 2012, 10:19 PM
gninnam gninnam is offline
Well, finally started the process of servicing the car
Carried out the easy bits this afternoon - air filter and spark plugs.
Thanks to Amar managed to get a good deal on the parts so off we go
A few pictures as words are boring
A view of the engine with no plastic on and one of the plugs out:
Which ones the old one?:
Old air filter was very poor quality compared the new one (Bosch):
Where the filter came from (what is the item at the bottom?):
Lost a screw that holds the coil packs to the engine down the engine - will get it out tomorrow when I take the tray out to do the oil change.
Will continue tomorrow
Andy.
Current cars:
BMW i4 M-Sport
Peugeot 207 (the sons)
Gone but not forgotten
Old 24th March 2012, 10:27 PM
47p2's Avatar
47p2 47p2 is offline
Very satisfying doing your own work on the car, I serviced my wife's Mini today, took the best part of 40 minutes from start to finish.
That air filter looks like it's not been changed for a long time.
Nite Blue 3.0L SE Quattro
Old 25th March 2012, 06:15 AM
I personally would leave the oil filler cap on while your working on the top of the engine. If you had dropped you coil pack bolt in there it might have made the job very complicated
Old 25th March 2012, 09:22 AM
i must be fairly close to you, i use IVC too if you still need to reset it with vagcom
Old 25th March 2012, 10:34 AM
Yes please
Will be in all day as trying to do the final stages so PM me with your number if you can make today
I had to take the oil cap off as I didn't have an extension bar so it was stopping me from getting any leaverage on the coilpack nuts
Point taken though (it was put back on when I started to do the rest though)
Andy.
Current cars:
BMW i4 M-Sport
Old 25th March 2012, 10:38 AM
pm sent
Old 25th March 2012, 07:31 PM
Well - didn't go to plan
Plugs changed
Air filter changed
Oil changed
Oil filter changed (what a b@st@rd)
Brake pads (half done)
Didn't check all the pads in the box as assumed they are good so fitted one side OK.
Started on the other - removed all the old pads then started to put the new ones in but hit a problem - see pic:
3 of the same so won't fit
So, had to put the old ones back in and put the car away, Not at home until Thursday so will try and get GSF to replace the wrong ones - not going to take the ones I have put in..........)
On Thursday will also change the fuel filter then put new tyres on the front and off on holiday to the French Alps
Just hope I can get it all done by then
Andy.
Current cars:
BMW i4 M-Sport
