Old 25th March 2012, 09:22 AM
i must be fairly close to you, i use IVC too if you still need to reset it with vagcom
Old 25th March 2012, 10:34 AM
gninnam gninnam is offline
Yes please
Will be in all day as trying to do the final stages so PM me with your number if you can make today
I had to take the oil cap off as I didn't have an extension bar so it was stopping me from getting any leaverage on the coilpack nuts
Point taken though (it was put back on when I started to do the rest though)
Andy.
Current cars:
BMW i4 M-Sport
Peugeot 207 (the sons)
Gone but not forgotten
Old 25th March 2012, 10:38 AM
pm sent
Old 25th March 2012, 07:31 PM
Well - didn't go to plan
Plugs changed
Air filter changed
Oil changed
Oil filter changed (what a b@st@rd)
Brake pads (half done)
Didn't check all the pads in the box as assumed they are good so fitted one side OK.
Started on the other - removed all the old pads then started to put the new ones in but hit a problem - see pic:
3 of the same so won't fit
So, had to put the old ones back in and put the car away, Not at home until Thursday so will try and get GSF to replace the wrong ones - not going to take the ones I have put in..........)
On Thursday will also change the fuel filter then put new tyres on the front and off on holiday to the French Alps
Just hope I can get it all done by then
Andy.
Current cars:
BMW i4 M-Sport
Old 25th March 2012, 08:48 PM
Also respect to Limoncello - turned up today and reset the service indicator plus carried out a scan.
Not to bad (a few knowns such as the alarm not being right and one of the rear Potentiometer for the vent - which I had disconnected) no serious ones but will require a check when I come back.
Andy.
Current cars:
BMW i4 M-Sport
Old 26th March 2012, 09:10 AM
your welcome
most of your faults were years old
had to send you the scans by text on pm as couldnt attach anything hope they came out ok
we can rescan after the holidays just to check, have a good time
Old 29th March 2012, 11:38 AM
GSF wouldn't replace just the wrong parts so had to take the new shoes out of the calipers.
Swapped and put them all in this morning.
Ready for the trip this weekend to the Alps
Andy.
Current cars:
BMW i4 M-Sport
