Old 22nd September 2012, 05:39 PM
71camaro 71camaro is offline
Default Need Xenon Plus bulb sizes
Hey all, I'm in desperate need of the bulb sizes for the Xenon Plus lamps. I know the Xenon is D2R but I need the others (turn signal, sidelight, tap to pass). Thanks.
Old 22nd September 2012, 05:43 PM
Turn signal is the same bulb as the standard lamps, so you should be able to use the ones in the holder already.
Old 22nd September 2012, 05:48 PM
Is it the same as the ones here in the USA though? Which I believe is 1157?
