Old 18th September 2012, 05:13 PM
As far as I know self levelling rear suspension is hydraulic on D2 and runs from power steering pump.
Old 18th September 2012, 05:27 PM
71camaro 71camaro is offline
Well, I'm unsure about any of that since we didn't get that over here, but I wouldn't want anything else running off the engines. These are pretty standard compressors for this sort of setup. They fill the tank very quickly.
Front struts are here so I hope to fab and install them today. I think I'll have the rear mounts done and the bags in as well.
Old 18th September 2012, 05:31 PM
Pretty sure the D2 rear suspension was hydraulic.. There are power steering pumps with additional outputs for it.
Old 18th September 2012, 07:42 PM
47p2's Avatar
47p2 47p2 is offline
I don't know why car manufacturers can't make the compressor run off the engine the same as trucks. I don't ever remember having a problem with air suspension in a truck with this set up and the millions of miles I drove them
Nite Blue 3.0L SE Quattro
Old 20th September 2012, 02:40 PM
Roger the hydrolics. Didn't realise that. Given that MTM ran a Supercharger of the front of the engine there is plenty of opportunity to run a compressor. I have an article somewhere where a guy converted an A/C compressor to air. I'll dig it out when I get home.
I've added this to the sticky.
Old 20th September 2012, 04:14 PM
Don't have time to post the full write-up right now, but here's it on the ground. I'm pulling out the bags again and modifying them to go lower...
Old 20th September 2012, 04:19 PM
sarg sarg is offline
lower?
It looks too low as is, and desperately shows the need for spacers or wider wheels too
2002 Mark's D2 S8 FE
2000 FL D2 4.2 QS - SOLD 2011
Old 20th September 2012, 05:00 PM
lower?
That's the beauty of it, I can raise it 6.5 inches from there by pressing a button.
Clearly this isn't how it will sit when finished, I have wheels and tires for it, but why would I mount them while still doing body work and the like?
Old 26th September 2012, 04:57 AM
Haven't forgotten you all, but I've been so busy with getting the car ready for a show of late I haven't had time to post updates. Assured they will be coming.
Old 26th September 2012, 07:45 PM
Night Train's Avatar
Impressive, most impressive (to paraphrase Darth Vader)
Other vehicles
Oh Yes....... The '98 PF S8!
