Old 26th June 2013, 12:21 PM
Interesting, mine was there too, above the central air intake. Says 750+50g though of R134a.
And I thought it also said 250cc of PAG oil in the original fill, though you normally only replace what comes out when servicing!
This web site is useful to confirm how much of what you need and agrees with the above: http://www.idqusa.com/lspt.php
Don't forget that's for my 3 litre A6, not the S8. It has a smaller/more modern air-con system. I was surprised by how little gas it needs. Old cars of mine from late 90s/early 00s have taken nearer 1kg of gas!
Old 26th June 2013, 05:30 PM
Well got it done this morning - sticker with weights of gas and oil was on the underside of the bonnet, up near the hinges, so took a bit of spotting!
Was worth doing - stickers says 550g +50 for gas and 22cc oil
The machine pulled out 250g of gas, so that was pretty low. Also pulled 13cc of oil
Now filled up with 575g of gas, 23cc oil and 10cc of UV additive in case it springs a leak!
thats interesting, if yours is a BBA engine, the tolerance data says
R134a 530g +/- 20
oil is PAG 130 cm3 +/- 10
Old 26th June 2013, 05:55 PM
Engine code is ASN Neil
Old 26th June 2013, 06:35 PM
Just checked the sticker again - defo 550+50g R134a and 220ccm PAG oil
The German are fond of their deca (10) units so I presume there's a factor of 10 difference in whatever the Italian machine used has put back in! Slightly more oil gone back in than required, but I'm guessing that's not a problem in system pressure terms as well within the maximum gas weight.
I looked under the bonnet of the S8 and as per HPs post it's more like 750g+50 for the D2
Old 27th June 2013, 08:22 AM
Manufacturers are actively trying to reduce the amount of refrigerant needed in modern cars as in a front end smash the gas is invariably released into the atmosphere, which is tough to avoid as they need the front facing cooling....
Hence the newer the car, typically, the less gas it needs.....
Old 27th June 2013, 09:17 AM
You think they could come up with a solution that uses an intermediate heat exchanger and secondary circuit to the radiator though; some sort of heat pipe or heat pump with a different less dangerous fluid in the vulnerable area?
Old 27th June 2013, 09:41 AM
how strange - the tolerance data says 800 +50 now against that engine!
oil it says - Zexel compressor: VW G052 154 A2/ 250 - 300, Denso compressor: VW G052 300 A2/ 250 - 300.
Old 27th June 2013, 11:09 AM
Maybe it changed during production, or is different for different markets?
Is that data predominantly USA?
Old 27th June 2013, 11:15 AM
The link I posted is I think USA and is consistent with your label.
Old 27th June 2013, 01:11 PM
One thing I don't understand about damaging atmosphere and ozone layer in particular is that R134a is heavier than air. Law pf physics. If released or leaked it will gather near soil and won't 'go up'. Perhaps I need to do some googling to understand how damage actually occurs.
