Old 2nd October 2013, 02:44 PM
Mine has been locked in the garage since I got back from Sergey's on Saturday - I'll be pulling it out on Friday morning to take it for a wheel refurb so if at that point the symbol is still showing it will have been working fine getting a signal from inside my garage. Will confirm Friday on the result
This statistics is very important. Please keep us updated.
Old 3rd October 2013, 08:48 AM
Mine is still good this morning - Sunday to Thursday, sat in the drivers knee cubby hole. Parked outside.
Old 4th October 2013, 04:14 PM
Mine has been locked in the garage since I got back from Sergey's on Saturday - I'll be pulling it out on Friday morning.......................
So is it OK or not when garaged?
Mine is still fine.
Old 4th October 2013, 04:24 PM
Yep, been fine while garaged
I've dropped the car off for a wheel refurb today - pick it up tomorrow so once it's been driven and put away in garage I'll check it still works
Can't see it being a problem anyway - seems to work fine in factory position
Old 5th October 2013, 10:10 AM
because I have ski hatch in my car I'm going to extend receiver wires buy ~3 meters and snake them temporarily to boot area via the ski hatch. I'm going to try to find good reception area. The first place I'm going to try is under rear parcel shelf. There is good access there via boot. We have 4 circular holes in the aluminium chassis between boot area and parcel shelf. I'm going to stick receiver under parcel shelf through those holes in the boot and there is just enough space for the receiver.
In parallel I'm going to order monster DCF antenna from Germany.
Update:
I have done 1+ week testing and I have stable reception in the boot under parcel shelf. Leaving receiver there permanently is a good option.
I also ordered new receiver from Audi (£60) as I believe my is not tuned good enough. 'Tree test' failed while Adrian's receiver worked tip top on the same spot. Want to mount that receiver in OEM spot when I get there when refreshing RNS-E project starts.
Discussion with zee Germans about industrial grade receiver still continues...
Old 5th October 2013, 01:47 PM
Picked mine up from its wheel refurb earlier and despite being parked overnight in an industrial building (basically in a Faraday cage) complete with a Bentley Continental parked right over it on a hoist(!) it managed to keep signal. I will be parking it up after the weekend as per usual so if it is still showing the antenna symbol next Friday when I get the car out I can be 100% certain it has picked up a signal at some point while garaged.
I'm pretty confident it's working exactly as intended
Old 7th October 2013, 11:38 AM
That does sound plausible given your "tree test" and compared to Adrian's.
Mine had lost the signal on Sunday morning, but recovered it by today. Though it was still "spot on" compared to the Radio 4 "pips" yesterday evening.
But it's still in the drivers knee hole, so pretty shielded there - must tidy up the cabling and move it soon.
Interested to see how quickly it picks up (assuming it does) on the change from BST to GMT in a couple of weeks time.
Old 16th October 2013, 11:44 AM
* If all synch sessions at 3am, 4am and 5am ended with failure cluster makes additional synch sessions after each trip.
I can confirm that works.
As I still haven't sorted out a good permanent location for mine it occasionally (depending on use) loses the radio synch and the little aerial disappears from the display.
When that happens, as I leave the car (after a drive) I move the receiver up onto the dash (it just reaches by the A-pillar) and invariably on return it's synch'ed again.
Old 16th October 2013, 12:03 PM
I can add that I finished installing Hormann doors in my garage and I now parked car in garage with receiver installed under rear parcel shelf. I will know tomorrow after 3+ full days in garage if receiver works under parcel shelf in the garage.
I think a lot of people here are waiting for an easy 'under knee panel' solution, so you HP blaze the trail !
I'm inclined to install receiver in OEM location, like we did with Adrian, as I'll be trying to upgrade my RNS-E to '2010+ RNS-E' and will be tidying up that area anyway.
Old 16th October 2013, 12:18 PM
At least the original bracket is still available so it's not too tricky now we know how to approach it. Am currently looking at some trim removal tool sets on eBay for future use!
