Old 21st September 2013, 12:03 PM
While Goran is helping with gathering statistics of how genuine Audi clock antenna behaves in the UK in genuine location in a car with heated windscreen I'm continuing my research.
I have found out that on many audi models clock receiver is mounted in rear bumper area.
Next step: because I have ski hatch in my car I'm going to extend receiver wires buy ~3 meters and snake them temporarily to boot area via the ski hatch. I'm going to try to find good reception area. The first place I'm going to try is under rear parcel shelf. There is good access there via boot. We have 4 circular holes in the aluminium chassis between boot area and parcel shelf. I'm going to stick receiver under parcel shelf through those holes in the boot and there is just enough space for the receiver.
In parallel I'm going to order monster DCF antenna from Germany.
ID:	6705   Click image for larger version
Old 21st September 2013, 10:09 PM
I drove the car twice today, once in the morning and once at night, about 30mins each time. The little antenna symbol was there all the time as far as I could tell, it didnt dissapear at any point.
Old 22nd September 2013, 07:50 AM
Thanks Goran! Keep us updated.
Old 22nd September 2013, 11:38 AM
Decided to spend some time studying behavioural pattern of cluster/receiver
I measured voltage on receiver inputs and was surprised there is nothing there -- cluster doesn't keep receiver under power all the time. So I connected a LED (basically a bulb) to receiver power inputs and waited a bit. Nothing happened
Then I drove car and when I switched off ignition and removed key after the trip the LED immediately came ON (but only for about 5-10 minutes, I didn't measure exact length).
Interestingly, if you just switch engine on/off when car is stationary and remove key, this will never happen. Cluster should receive a bit of speed signal when ignition was ON. Only in this case the receiver gets power from cluster for 5-10 minutes when ignition goes OFF.
Taking into account signal structure (it takes one full minute to receive time and date signal) there are only 5-10 attempts to read time from air until cluster shuts down the receiver.
Perhaps receiver is switched ON at random time periods when car is parked. I will learn about it soon.
UPDATE: Receiver is always OFF while driving. If receiver was ON after accomplished trip and then I decide to continue journey, the receiver will go OFF immediately when I switch on ignition.
Old 22nd September 2013, 07:38 PM
Sunday update.
Antenna symbol was there toady too, did not dissapear as far as I can tell.
Old 22nd September 2013, 08:47 PM
Many thanks Goran. We need to understand if antenna symbol sometimes disappears in your car. That will indicate a need for more powerful receiver antenna.
Old 22nd September 2013, 08:50 PM
Where is your receiver at present?
Old 5th October 2013, 10:10 AM
Update:
I have done 1+ week testing and I have stable reception in the boot under parcel shelf. Leaving receiver there permanently is a good option.
I also ordered new receiver from Audi (£60) as I believe my is not tuned good enough. 'Tree test' failed while Adrian's receiver worked tip top on the same spot. Want to mount that receiver in OEM spot when I get there when refreshing RNS-E project starts.
Discussion with zee Germans about industrial grade receiver still continues...
Old 5th October 2013, 01:47 PM
Picked mine up from its wheel refurb earlier and despite being parked overnight in an industrial building (basically in a Faraday cage) complete with a Bentley Continental parked right over it on a hoist(!) it managed to keep signal. I will be parking it up after the weekend as per usual so if it is still showing the antenna symbol next Friday when I get the car out I can be 100% certain it has picked up a signal at some point while garaged.
I'm pretty confident it's working exactly as intended
Old 7th October 2013, 11:38 AM
That does sound plausible given your "tree test" and compared to Adrian's.
Mine had lost the signal on Sunday morning, but recovered it by today. Though it was still "spot on" compared to the Radio 4 "pips" yesterday evening.
But it's still in the drivers knee hole, so pretty shielded there - must tidy up the cabling and move it soon.
Interested to see how quickly it picks up (assuming it does) on the change from BST to GMT in a couple of weeks time.
