Old 3rd January 2014, 10:02 PM
texas2201 texas2201 is offline
Default Steering column clunk and wandering
car was in having the bumper fixed from when my wife had an argument with a supermarket car park - the Audi lost
The mechanic mentioned that when he was manoeuvring the car he could hear a clunk from the column and then on test drive it was wandering and needs constant correction
His suggestion was that maybe a UJ was worn in the column?
Does the A8 have UJ's in the steering column?
if not does this mean a new column needs to be fitted? How big a job is this?
Old 4th January 2014, 12:40 PM
also if I go through a puddle with the nearside front wheel I lose PAS and the steering gets really heavy - no pas
Old 4th January 2014, 12:50 PM
mannyo mannyo is offline
PAS pump is belt driven, water could be getting on the belt causing it to slip. If I recall on LHD cars the pump is down on your nearside.
Manny
Past
Old 4th January 2014, 02:14 PM
It is a RHD car - and I asked the garage to look at that and they said the belt was OK
Old 5th January 2014, 11:08 AM
My S8 has the same symptoms, play in steering and clunk when going over bumps. And its just had a new front suspension and all the suspension arms checked professionally so its not those.
I was searching on quattroworld for answers and they suggest adjusting this, as per ElsaWin original procedure.
Worth a try as its a free fix.
Elsawin:
Adjusting power-assisted steering box
Two mechanics are required to perform adjustment. Adjust with engine switched off.
‒ Lift vehicle on lifting platform.
‒ Wheels in straight-ahead position.
‒ By turning the steering wheel back and forth (about 30°around centre axle) a rattling noise will be heard if there is excessive steering play.
‒ → The second mechanic should carefully turn the adjustment screw (arrow) until the rattling noise can no longer be heard inside the vehicle.
‒ Carry out a test drive.
‒ Ensure that when manoeuvring or negotiating corners the steering automatically returns smoothly to the straight-ahead position. Adjust setting if necessary.
Old 5th January 2014, 04:17 PM
thanks I will get them to try that - I have checked nearly everything else
Old 5th January 2014, 04:49 PM
SilverS8 SilverS8 is offline
My S suffer from play when engine is on and nothing while off.
I'm just about to ordet a new steering rack from Germany.
Maybe i should try this trick frist.
2003 Daytona Grey RS6
2000 Silver S8
2005 A6 1.8TQ Premium
Old 5th January 2014, 05:30 PM
sarg sarg is offline
Steering rack replacement is a serious pain in the ass, fingers crossed for you it's not the rack
2025 Hyundai Ioniq 5 N
2020 BMW M340d xDrive
Old 6th January 2014, 01:49 PM
I know had it done a few years ago - terrible job :-)
Old 21st January 2014, 06:13 AM
My garage said there was no screw inside the bolt? when it says screw does it mean turn bolt? and it is a typo or have I and adjustment screw missing?
