Old 19th February 2014, 12:14 PM
Dan Dan is offline
Default Suspension noises
Hi folks.
The only thing occasionally spoiling the otherwise serene calm of my 8 is, I think only on the offside front, the odd crunching / crashing sounds, although only really on speed bumps / larger potholes etc. The car has been checked over and other than the usual wear on some of the bushes, no issues were obvious. I have only been running the car on "dynamic" setting to date.
Today, and on reading other threads re air suspension noises etc, I put the car into both "lift", and "comfort" modes. The car seems to go up and down without undue fuss so all seems to be working correctly. What I did notice however, although it was a relatively short drive, is that the o/s front suspension crunch seems not to occur when in these higher modes.
Given the above, does anyone have any idea as to the likely suspects / culprit of the noises when in dynamic? It seems chasing suspension noises can be a long and expensive process for what I've read.
Thanks
Old 19th February 2014, 02:53 PM
you haven't got an arch liner thats dropped a bit etc so that the trim rubs when its on full suspension travel, but only when its lower?
Old 19th February 2014, 03:15 PM
Dan Dan is offline
That's a very good suggestion. Hadn't thought of the simple solution! I have to say it doesn't sound like that kind of noise, but certainly worth a good poke about to check. Thanks
Old 19th February 2014, 07:24 PM
Dan Dan is offline
I may have spoken too soon based on the brief run. The noises remain whatever setting suspension is on. Any further thoughts welcome. May get the wheel off to have a good poke about, but the difficulty is obviously recreating the issue with the car stationary!
Old 19th February 2014, 10:04 PM
Could also be that the 'usual wear' might be fine for lesser vehicles, but the '8 is transmitting the noise through the car.
Old 19th February 2014, 10:31 PM
Dan Dan is offline
Thanks.
Might get it up on some axle stands take the wheels off and have a good poke about.
Old 20th February 2014, 07:00 AM
Dont forget to engage jack mode before raising the car, otherwise it will attempt to self level as you jack up.
Old 20th February 2014, 07:32 AM
Try looking at the inner top arm bushes with a bright torch.
You don't need to jack the car, just put in lit mode and getting a helper to turn the steering can help the metal arm move to reveal more bush. They usually crack circumferentially.
