Old 4th June 2014, 01:10 PM
sarg sarg is offline
Anyone know how to remove the wing mirrors?
Wait until the Annual Meet attendees come up the A82 by Loch Lomond. I will ensure all are warned. Dont want people arriving minus wing mirrors or with a great scrape down the side. The Lochs and Glens coaches dont take prisoners and the collapsing walls are a hazard all by themselves.
Sorry
2025 Hyundai Ioniq 5 N
2020 BMW M340d xDrive
Old 4th June 2014, 01:36 PM
To remove the mirror completely from the car or just the cover from the mirror?
Cover off should be easy, have a look on the underside for a couple of screws (not 100 % about D3)
Mirrors off the car will be bolts from the inside of the door, behind the plastic panel.
Old 4th June 2014, 01:58 PM
On D2 you need the door trim panel partly or fully off as well, depending on the mirror type/connections and what you need to do.
Replacement (which I did) of a D2 S8 mirror definitely needs the panel off to get at some of the wiring.
Old 4th June 2014, 02:14 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
The whole mirror.
I can take it back to the bench to do it in the warm and comfort.
The A4 mirrors is door card off, 2 bolts and one plug.
[center]
06 3.0TDI Quattro:
Options:
Old 4th June 2014, 02:30 PM
This thread suggests it's a door card off job, and then some : http://forums.audiworld.com/showthread.php?t=2816588
Old 4th June 2014, 02:49 PM
ScottD3's Avatar
Need to remove the carrier and window frame assembly to remove a mirror.
That seems daft.
I'll leave that till I got another job needed for in there.
Possible when I do my handles.
[center]
06 3.0TDI Quattro:
Options:
