Old 4th June 2014, 07:09 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Default Wing Mirrors Service
I folded my mirrors in this morning and thought they seemed a bit noisier and sluggish than normal.
I was wondering if its possible or if anyone has taken the mirrors apart and greased the motors up?
[center]
06 3.0TDI Quattro:
Options:
Old 4th June 2014, 07:54 AM
I've sort of done it on a D2, but not a D3.
Nothing there that you could realistically get at, but with the mirror disconnected and turned upside down I put large quantities of WD40 etc. into obvious holes and cracks while "exercising" the mechanism and it improved hugely.
It's a while back now, but I think the first time I did it was totally off the car and using a 12V power supply to drive it.
Old 4th June 2014, 08:38 AM
ScottD3's Avatar
That's my thinking.
I've noticed on other motors from Audi that they tend to dry out and need a good greasing.
Thinking of doing it to my mirrors.
[center]
06 3.0TDI Quattro:
Options:
Old 4th June 2014, 08:48 AM
I think it's more the gear mechanism than the motor, combined with grit/dirt it jams the teeth.
Old 4th June 2014, 08:50 AM
ScottD3's Avatar
Yeah. all of that lot.
Clean, grease, done.
[center]
06 3.0TDI Quattro:
Options:
Old 4th June 2014, 09:11 AM
No not WD40, that's just a short term solution, you will just wash whatever grease is in there out and WD40 will dry out itself in a day or 2.
You to take it apart, clean re-grease and re-assemble.
Old 4th June 2014, 09:14 AM
I'm summarising badly.
Dismantling wasn't feasible (for me anyway) - pretty much a sealed unit.
I used WD40 and thin oil to flush it then topped up with thicker stuff and grease pushed in.
Old 4th June 2014, 12:47 PM
I'm sure I can break something else of yours electrically speaking if I try up at the meet Andrew
Old 4th June 2014, 12:48 PM
I'm rather hoping that the assembled expertise will be able to fix my "beached" OSR headrest.
The ineffective whirring noises suggest a mechanical, not electrical, "disconnect" of "architectural" origin.
Old 4th June 2014, 12:56 PM
ScottD3's Avatar
Anyone know how to remove the wing mirrors?
[center]
06 3.0TDI Quattro:
Options:
