Old 2nd October 2014, 08:41 PM
Thumbs up Installing S2T Paddle Shifters
My new paddles finally arrived and below is a quick install guide.
If you are interested in buying a set, contact an amazing and extremely helpful guy Tony by filling a contact form on www.tgdperformance.co.uk
First remove the caps on the back of the wheel to gain access to 2x big torx bolts in order to remove the airbag.
It is recommended to keep ignition off and pull Airbag fuse as well.
Ideally you don't want to disconnect the airbag so turn the wheel upside down by 180degrees for this install
After dropping the airbag down so it sits on the steering wheel, pull the plastic ring out, be careful to not put to much force and possibly damage the airbag wiring. Hold the airbag with one hand to prevent falling off the steering wheel. There are four pins holding the plastic trim.
Next slide out the steering wheel buttons to gain access to 2x small standard torx screws, but before removing them unplug the paddles connectors from the side of each button.
Remove the paddles from the steering wheel.
Next grab a thin flat head screwdriver and through the slot behind the paddle push securing pin out. Pull the pin out with pliers in order to separate the paddle from the base.
Before you install new paddle, shave off with a stanley knife a tiny bit of plastic from each securing brackets on both sides. I found this to be the only issue with this install.
Fit new paddles onto the base and push the pin all the way back until it clips in. If it sticks out a bit that means it's not fully in.
Here is your new paddle ready to fit back in onto the steering wheel.
Refit everything back together in revers order.
And here they are. So much better feel than the plastic ones. You will almost always find them no matter how you hold the wheel, almost
The actual gear change feels so much better, no more that plastic noise and feeling, so much better.
Really pleased with them, plus the Polished Clear finish matches interior chromes very well.
They are really comfortable and very quiet
ID:	9156   Click image for larger version
ID:	9157   Click image for larger version
ID:	9158   Click image for larger version
ID:	9159   Click image for larger version
ID:	9160   Click image for larger version
ID:	9161   Click image for larger version
ID:	9162   Click image for larger version
ID:	9163   Click image for larger version
ID:	9164   Click image for larger version
ID:	9166   Click image for larger version
ID:	9167   Click image for larger version
ID:	9168   Click image for larger version
ID:	9169   Click image for larger version
ID:	9170   Click image for larger version
ID:	9171   Click image for larger version
ID:	9172   Click image for larger version
ID:	9173   Click image for larger version
ID:	9174   Click image for larger version
Old 2nd October 2014, 09:46 PM
gninnam gninnam is offline
Nice write up and they look nice too
Andy.
Current cars:
BMW i4 M-Sport
Peugeot 207 (the sons)
Gone but not forgotten
Old 2nd October 2014, 09:53 PM
Nice detail.....
So much so - A 3.7 with heated steering wheel ? For real ?
Old 2nd October 2014, 10:30 PM
Nice detail.....
Ha ha ha
Old 2nd October 2014, 10:43 PM
I'm trying to laugh from this all 3.7 comments, it is only 3.7 but it's mine
Own by me, not bank. Mechanically it's very good, gearbox is smooth as hell, has lots of gadgets missing, but heated seats all the way, aluminium pack, comfort seats, kessy, voice control, bluetooth, heated steering, wheels and windscreen and that's about it really.
But few nice details added to it, at least in my opinion, like S8 grill, no S8 badge of course !!!, Bi-Xenon AFS headlights, not fully wired yet , and I love it
ahh, and a proper hand build exhaust which is not everyone's cup of tea, but I love it to bits. Remap done and gearbox remap is on the things to do soon as well so it's not that bad for a 7.3
Old 2nd October 2014, 11:13 PM
Its a credit to the ranks of the ever growing and popular 3.7 - 7.3 division!!
Old 3rd October 2014, 09:57 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Depiste the issues with the engine, its still the best colour on a A8.
Fact End, Mini adventure!!
[center]
06 3.0TDI Quattro:
Options:
