Old 14th April 2015, 01:07 PM
Default Hvac doesn't know who's the boss
Hvac controls on my car appear to be coded for left hand drive but unfortunately there is no coding info or label files for it.
Is everyone's the same or is it just mine?
You can find out by pressing the fan speed button on your side and see if it says driver or passenger
Old 14th April 2015, 02:04 PM
Mine certainly says Driver for Driver and Passenger for Passenger correctly for RHD. I did test drive another '8 where is was labelled for a LHD car but didn't think much of it.
I don't know if this coding from an A6 may help?
http://wiki.ross-tech.com/wiki/index...rom_MY_2002%29
Matt
Old 14th April 2015, 02:31 PM
Try this Del,
Go to the MMI secret menu (car+setup)
Go to Diag Settings
Uncheck Linkslenker (this is the setting for left hand drive vehicles)
Restart the MMI
Climate control should be back to the settings for a right hand drive car now!
Matt
Old 14th April 2015, 03:58 PM
No idea how you found that out Matt but your bang on it.
Cheers fella, I love this forum
Don't suppose you have a label file for 08 hvac do you ��
Btw I got your nav disk installed after removing the DVD lock, works a treat.
Old 14th April 2015, 04:36 PM
Excellent!
Not sure about a label file, is this what you want from VCDS?
Code:
Address 08: Auto HVAC        Labels: None
   Part No SW: 4E0 910 043     HW: 4E0 820 043 A
   Component: KLIMAAUTOMAT    015 0240
   Revision: 00000018    Serial number: 00000000023996
   Coding: 1069057
   Shop #: WSC 02311 785 00200
   VCID: 5ABB8B6F950D75F140B-800F
No fault code found.
Matt
Old 14th April 2015, 05:22 PM
See where it says label none, that means there is no tags for the info coming out when using measuring blocks.
Its a pain, when trying to fault find A/C for example.
There's quite a few controllers that don't have labels and it bugs the OCD in me TBH
Old 18th April 2015, 10:18 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
You can make your own label file.
Use ELSA for what each section is, add it to a file and your done.
I hate not having label files.
[center]
06 3.0TDI Quattro:
Options:
