Old 24th January 2016, 12:50 PM
cringing at the though of it
Old 25th January 2016, 09:20 AM
Conquistador's Avatar
Ah yes, forgot about that guy who does the 'bagpipe' kits, I'll buy one of them to renew the parts anyway. I bought one for my first D3 when the suspension was getting a bit tired on that.
And I'm not going to "slam it to the weeds" in the word of Edd China, just was curious to see what a drop of 15mm or so would look like and probably wouldn't be permanent.
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 26th January 2016, 03:27 PM
Well because I couldn't complete the VCDS lowering process (you must fully complete adaptation), I've got the orange suspension warning light and the adaptive function of the headlights and cornering lights aren't working -__-
Got the new kit from bagpipingandy coming tomorrow so hopefully this will fix it and I'll be able to complete the adaptation!
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 26th January 2016, 04:36 PM
Trying doing a test on the compressor first using vcds with the help of the label file from the following thread
http://forum.a8parts.co.uk/showthread.php?t=10823
If you watch the following video you can see how to test the compressor, ignore the other waffle as it was related to somebody else's issues.
If you watch until the point of login then skip to 14:30 you will see how to test the compressor
https://youtu.be/OU5SBmHQIfI
Old 26th January 2016, 09:56 PM
Thanks Del. Copied the label file across but still have an error when I select pressure accumulator charging and doon't have the on/off/next button up the top. Measuring blocks shows compressor temperature at 28.0c and 11.39 bar pressure
Only suspension fault code present at the moment is:
Tuesday,26,January,2016,22:51:13:33490
01437 - Control Position not Learned
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 52
Mileage: 167520 km
Time Indication: 0
Date: 2016.01.23
Time: 18:11:42
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 27th January 2016, 09:34 AM
Thats after entering the security code right?
If you don't enter the security code you cant run test either.
Before basic settings click on security-16 and enter the code
Also if you do get at it remember the test will only run for a minute, i had to do mine a few times to to get to 16 bar which is the max
Old 27th January 2016, 01:10 PM
Yeah I definitely went through security access, then when I clicked Do it! after typing 08367 I got a little error box saying it wasn't possible.
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
