Old 6th June 2016, 04:55 AM
Daz 70 Daz 70 is offline
Default Passanger Seat Memory
I've already done this Mod on my 97 A8... was bored a few years back. Did buy the bits From A8 Parts..
In my case I stripped a drivers seat for the wiring and the Memory Module.
The sensors basically fit the other way around
Basically the different between the Memory and non memory wiring is that the non memory... the switches go directly to the Motors... where as the Memory, the switches go to the memory module and the motors go to the memory module... hence easier with a loom as a lot of hacking otherwise.....
You do indeed (as stated) also have position sensors that feed into the memory module....
I had to buy the trim piece from the dealer for the passanger door. I also modified the unit so that you don't have to keep you finger on the memory position. (much nicer)..
Whichever way you go will be somework... while getting a drivers seat from a LHD car would be simple... it does not (that I'm aware of) contain the seat sensor so would need to modify that...
To be far mine does not really get much use...... but from my point of view..... whenever the passangers have gone... and I get back in the car the seat resets back to the default (well depending on key fob) position... which imo is a deffo a bonus.
If you decide to go ahead and need any help... I should still have a load of pics from when i did mine.....
Daz
Old 6th June 2016, 08:01 AM
True - There is no airbag occupancy module in the drivers seat, so it wouldn't be plug and play, although the occupancy sensor is so prone to failing they are often bypassed to get the airbag light off...
Great to hear someone has done the whole retrofit, I've hypothesised its relatively straightforward, if tedious possibility, but never seen it done
Sharing a couple of photos of fitting the position sensors would be interesting for all to see if you have any
