After many posts re-iterating John at Mackies of Glasgow statements about how the 5HP24 box is a perfectly OK bit of kit, i arrived back home last night from Audi Driver International having driven some 1000miles in 3 days without having skipped a beat. However, went to reverse out this morning to go for a swim and it went into PRNDS
![]() Any suggestions/recommendations?
Mine started to do that a few months ago, most mornings when I reversed out of the garage. I was about to do a scan with the VCDS when it just went away! Hasn't played up for months now.
If it's otherwise working fine it should just be the switch - it's not that bad a job to swap but the box ideally needs lowering.
There's 2 types depending on wiring so if it is that either order from tps or leave to the garage fitting it, to avoid getting the wrong one
My guess would be the F125 switch plug contacts. My car has done that a few times in the past, especially as the colder weather approached. Disconnecting the plug and cleaning the contacts usually fixes it for another year or two.
In my experience it can throw this message once in a blue moon, and then not appear again...hopefully yours will do the same.
Sometimes I think these cars really do have a personality though - maybe yours was reacting to the unexpectedly long drive to Englandshire and back.... ![]() |
VCDS scan shows:
1 Fault found: 17090 - Transmission Range Sensor (F125) P0706 - 35 - 00- Implausible Signal So it seems like it is the F125 switch. And, as the lower control arms need renewing and the switch is in that area, they might as well be done at the same time. The Audiforum guide on the process shows it is a DIY fix but I am not sure that some of the fiddly work involved is best (safely) achieved on jacks/wheel ramps.
Same as me and I plan to get the F125 switch replaced sometime.
Adrian_E had it done a while ago and I think he got a garage to do it as the gearbox needs dropping a bit to get access.
![]() My aged parents whom I was taking back up to Scotlandshire didnt even notice we doing 90ish. Just commented on the smooth ride and handling and lack of noise in the back. ![]()
Take care David, it can get a little more noisy in the back above the 90-ish kph that you reported doing. Wouldn't want the parents to experience any discomfort!
