Old 17th October 2016, 11:08 AM
In my experience it can throw this message once in a blue moon, and then not appear again...hopefully yours will do the same.
Sometimes I think these cars really do have a personality though - maybe yours was reacting to the unexpectedly long drive to Englandshire and back....
Old 17th October 2016, 12:43 PM
They do need a damn good thrashing every now and again! Maybe it took the hump
My aged parents whom I was taking back up to Scotlandshire didnt even notice we doing 90ish. Just commented on the smooth ride and handling and lack of noise in the back.
Old 17th October 2016, 01:12 PM
Take care David, it can get a little more noisy in the back above the 90-ish kph that you reported doing. Wouldn't want the parents to experience any discomfort!
Old 17th October 2016, 01:41 PM
I think he meant mph, rather than kph, Jim - or maybe it was age
Old 17th October 2016, 01:45 PM
Not like this though
https://youtu.be/mv0onXhyLlE
Old 17th October 2016, 04:43 PM
Mine gets the same code if I'm a bit too keen on the shifter when changing direction. As long as I make sure it's fully stationary for a moment or two it seems fine. Thats user error though I haven't had it for a few weeks since I figured out what I was doing wrong!
Old 17th October 2016, 05:00 PM
I tried it several times today and its perfectly ok and normal until i select reverse and then there's a pause - a hard clunk and then it goes into limp mode. It doesnt seem to be dependent on how quickly i select it.
I have just contacted Maria at Prestige Motor Services (our illustrious sponsor) and whilst they have a couple of 8 pin/round plug F125s, they dont have any of the later 10 pin/flat plug switches which I suspect my Jul 2002 registered AVP/FBG car needs. Does anyone know how easy it is to check the connector type?
Old 17th October 2016, 05:06 PM
Buy a new one, not significantly more.
Old 17th October 2016, 05:18 PM
If I remember correctly, the connector is reasonably accessible, somewhere near the front n/s driveshaft. It would be worth taking it apart and giving the contacts a clean while you're there; that's always been the (temporary) cure for me.
(Black, with all black premium interior and carbon fibre dιcor, 21" sonic carbon twin turbine wheels and FSD capability)
Old 17th October 2016, 06:37 PM
Thanks Andrew/Mark for that. I have read the Audiforum "how to" but its not clear whether the connector itself is easily accessable.
