Old 16th October 2016, 05:50 PM
I'll be very interested to find a reversing camera that will fit D2 numberplate light well perfectly. Or perhaps to modify the number plate light itself to accommodate the camera.
I happened to be looking at the XCarlink web site today Goran and noticed they sell a number of reversing cameras integrated with boot handles and/or numberplate lights.
None are the right shape/size for a D2 but the way they work is to use a small LED in place of the larger filament bulb.
I'm pretty sure one of the many types they sell "could" be modified, probably by cutting down a bit and fitting onto a backing plate, to directly replace a D2 light. In general the newer ones that they supply alternatives for are not so "long" but a bit "wider". The A6 one looks pretty close. http://www.xcarlink.co.uk/product.ph...&cat=25&page=1
Old 21st October 2016, 10:02 AM
I'd suggest to order A4 marine stainless steel screws from eBay to make sure they won't rust in that area.
The fixing bolts aren't into the bodywork, they go into what look like brass nuts embedded in the rubber well nuts so there's no contact at all with the metal of the boot lid.
Nonetheless I'll check them after a while and see if there's any corrosion and take "appropriate action".
Old 21st October 2016, 10:08 AM
It's still doing this at times, when disturbed, so my repair isn't perfect. I'll have to do a "proper job" sometime, probably when I resite it to a better permanent location.
That was referring to the colour loss on the green signal wire.
Not wanting to rewire the (now botched) plug I bought the audio adapter pictured below which has the right 14-pin connector on it.
I was going to cut off the two big sockets and just "graft/solder" it on to the loom (in place of the botched connector) but I'm wondering if I can buy plugs that fit those two sockets, anyone know what they are called? The actual cable is sold as "Kenwood Car Radio Stereo 14 Pin Molex Type Wiring Harness Loom Old Version ISO" so they may just be specific to old Kenwood equipment.
Old 21st October 2016, 10:27 AM
Matt
Old 21st October 2016, 10:33 AM
Many thanks Matty, so I need one of these now:
(might seem a bit complex but it will also add a bit of extra length to the loom which I really need)
Old 25th October 2016, 10:23 PM
It has a lead to a button for "video while moving" that seems to need to be "on" anyway for the reversing camera
OK, this doesn't seem to do anything useful; as I proved today, reversing at anything above walking pace cuts out the camera with the standard safety warning, whatever I do with this equipment.
So can anyone point me at the "real" VIM solution for RNS-D please.
Old 26th October 2016, 07:35 AM
Rummaging around online I've found various comments about cutting the GALA signal, either permanently or temporarily with an override switch, and it's the latter I'd want.
But then there are references to two different connections on the back of the RNS-D.
1. The clearly-identified GALA on an 8-pin connector (pin 1?)
2. A pin on the 26-pin connector, possibly #5, which seems to be marked DFA_L on diagrams I've seen. (there's also a DFA_R)
The Kufatec loom to do the job just seems to have 8-pin connectors (see picture) so I'd guess the switch on that just interrupts the first one.
I could buy one as they are not expensive, but unless access to the loom is really tricky it's an easy DIY wiring job. And I prefer not to add even more wiring and bulky connectors into an already-congested area behind the RNS.
Edit: Found the following, which sort of makes sense:
5 connection rear left speed sensor in dash panel wiring harness
17 connection reverse light in dash panel wiring harness
18 connection rear right speed sensor in dash panel wiring harness
Though whether those signals exist and what the RNS-D does with them is anyone's guess..............
(Could be for features not yet developed or not used on a D2, RNS-D not being that specific, or more likely for the SatNav)
Old 26th October 2016, 08:50 AM
Just had the RNS-D out and that particular bit of loom is one of the shortest and tightest I've ever seen.
Can't be bothered to take the glovebox out and side panel off to get at it, so Kufatec it is! (£25 delivered)
Edit: Out of stock at UK distributors, back-order from Germany, hopefully less than 2 weeks.
Old 1st November 2016, 10:40 AM
Much less, arrived today.
And checking connections it was pin 1 that the loom opens/closes, so:
2. 26-pin connector, Found the following, which sort of makes sense:
I reckon the GALA on the 8-pin is probably used simply to adjust volume and cut off the TV.
And the SatNav will use the information from the 26-pin connector.
Old 4th November 2016, 01:56 PM
I've just noticed a really stupid feature of the Kufatec loom.
The operating button (mine is round, not square as in the photo) has a nut and spring washer for securing it from behind (through a mounting hole), already fitted. Saves them getting lost presumably.
But it is of course impossible to fit that way without cutting the cable to the switch, the button has to be inserted from the front! So why didn't they put a small connector in that (2-wire) part of the loom, small enough to feed through a mounting hole and to slip the nut/washer over. Or provide a fixing that you attach and tighten from the button face side? So much for German attention to detail!
As it happens I'm using a different switch so it's not an issue for me as I need to cut that wiring anyway.
