#61
None are the right shape/size for a D2 but the way they work is to use a small LED in place of the larger filament bulb. I'm pretty sure one of the many types they sell "could" be modified, probably by cutting down a bit and fitting onto a backing plate, to directly replace a D2 light. In general the newer ones that they supply alternatives for are not so "long" but a bit "wider". The A6 one looks pretty close. http://www.xcarlink.co.uk/product.ph...&cat=25&page=1
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 16th October 2016 at 05:53 PM. |
#62
Nonetheless I'll check them after a while and see if there's any corrosion and take "appropriate action". ![]()
#63
Not wanting to rewire the (now botched) plug I bought the audio adapter pictured below which has the right 14-pin connector on it. I was going to cut off the two big sockets and just "graft/solder" it on to the loom (in place of the botched connector) but I'm wondering if I can buy plugs that fit those two sockets, anyone know what they are called? The actual cable is sold as "Kenwood Car Radio Stereo 14 Pin Molex Type Wiring Harness Loom Old Version ISO" so they may just be specific to old Kenwood equipment.
#64
#65
Many thanks Matty,
![]() (might seem a bit complex but it will also add a bit of extra length to the loom which I really need)
#66
So can anyone point me at the "real" VIM solution for RNS-D please. ![]()
#67
But then there are references to two different connections on the back of the RNS-D. 1. The clearly-identified GALA on an 8-pin connector (pin 1?) 2. A pin on the 26-pin connector, possibly #5, which seems to be marked DFA_L on diagrams I've seen. ![]() The Kufatec loom to do the job just seems to have 8-pin connectors (see picture) so I'd guess the switch on that just interrupts the first one. I could buy one as they are not expensive, but unless access to the loom is really tricky it's an easy DIY wiring job. And I prefer not to add even more wiring and bulky connectors into an already-congested area behind the RNS. Edit: Found the following, which sort of makes sense: 5 connection rear left speed sensor in dash panel wiring harness 17 connection reverse light in dash panel wiring harness 18 connection rear right speed sensor in dash panel wiring harness Though whether those signals exist and what the RNS-D does with them is anyone's guess.............. (Could be for features not yet developed or not used on a D2, RNS-D not being that specific, or more likely for the SatNav)
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 26th October 2016 at 07:52 AM. |
#68
![]() Can't be bothered to take the glovebox out and side panel off to get at it, so Kufatec it is! ![]() Edit: Out of stock at UK distributors, back-order from Germany, hopefully less than 2 weeks.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 26th October 2016 at 08:12 PM. |
#69
![]() And checking connections it was pin 1 that the loom opens/closes, so: Quote:
And the SatNav will use the information from the 26-pin connector.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 1st November 2016 at 10:54 AM. |
#70
I've just noticed a really stupid feature of the Kufatec loom.
![]() The operating button (mine is round, not square as in the photo) has a nut and spring washer for securing it from behind (through a mounting hole), already fitted. Saves them getting lost presumably. But it is of course impossible to fit that way without cutting the cable to the switch, the button has to be inserted from the front! ![]() ![]() As it happens I'm using a different switch so it's not an issue for me as I need to cut that wiring anyway. ![]()
