Old 30th January 2017, 12:53 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
RC Cars have similar dampers, but probably not worth the hassle of changing the ends or fashioning adapters.. Does it have a Nm rating on it? I would expect 200-400Nm. I think the damper just acts at the top of the armrest travel to catch it before it bounces off the endstop and then hold it wide open somewhat - once closing it doesn't seem to have any effect. What do other think?
Nothing on it, just Stab-o-matic and don't heat, cut and such.
I think you're right, it just stops it from slamming into the lower section.
[center]
06 3.0TDI Quattro:
Options:
Old 30th January 2017, 12:56 PM
I think you'll find that this is what you need -
http://www.nachbau-teile.de/a/stabil...(stabilus).htm
Old 30th January 2017, 12:57 PM
ScottD3's Avatar
Yup.
Found that but sadly.
SHOCK (Stabilus)
Manufacturer : Stabilus
Item number : 7726RB
EAN : 4046577196476
Recommended retail price. 27.50 € Our price:
24.70 EUR
10% cheaper!
As the recommended selling price
This item is no longer available.
Hence talking to SGS.
[center]
06 3.0TDI Quattro:
Options:
Old 1st August 2017, 11:45 AM
peiiider peiiider is offline
Anybody found these online yet ? Both of mine have jammed in the open position now the last two weeks, so I opened up the armrests and cut them out..
06 A8 3,0TDIq My daily driver and project...
97 A4 1,8Tq. Powered by a 4,2 from the '01 S6, full rollcage, FIA seats and 6-point harnesses, B5 RS4 KW Competition race suspension, B6 S4 brakes, 18" Toyo RS1 slicks, carbon fiber roof. V8 trackday racer
14 VW Caddy 1,6TDI from my employer..
(X)00 A8 2,8q, (X)97 A4 1,8Tq, (X)92 S4 2,2Tq, (X)92 80 2,3E
Old 2nd August 2017, 05:32 AM
Somerandomguy's Avatar
I got in cntact with the manufacturer and they confirmed that they are obsolete with no alternative part available. I did get the specs from them in case someone else makes something suitable and will post them up:
Extended length 89.5mm
Stroke 18.5mm
Rod diameter 6mm
Piston rod length 50mm
Extension force 100N
Tension force 45N
Old 2nd August 2017, 08:40 AM
I wonder if anyone could be bothered to adapt something like this...
https://www.aliexpress.com/store/pro...654325517.html
I can't
Attachment 16665
