Old 28th January 2017, 07:27 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Default Armrest Strut
Who knew the arm rest had a little strut?
[center]
06 3.0TDI Quattro:
Options:
Old 28th January 2017, 08:00 PM
Didn't know the D3 did, but the PF D2 did if it had a factory phone installed.
I tried and failed (dismally) to get a replacement gas strut some years ago (car has gone to the A8parts graveyard since then).
Old 28th January 2017, 08:07 PM
ScottD3's Avatar
I've just spent the last hour looking and it appears to be no longer avaliable.
Tempted to talk to SGS and see how much they want to re-gas it.
See if its worth the hassle to get in there and strip it down.
[center]
06 3.0TDI Quattro:
Options:
Old 29th January 2017, 08:21 AM
Turbo Tony's Avatar
Wow! Who knew, right?!
I don't think my armrest was especially damped in it's movement, so I don't know if that means I don't have a strut, or that the strut is knackered.
Hmmm....
Storytellers Villa Orlando
2008 Audi S8
Old 29th January 2017, 02:52 PM
ScottD3's Avatar
Hmmm....
I suspect the struts are broken.
Possibly due to people forcing the lids down and popping the seals.
Be good is SGS can refurbish them.
[center]
06 3.0TDI Quattro:
Options:
Old 29th January 2017, 03:01 PM
ScottD3's Avatar
Emailed SGS. See what they say.
[center]
06 3.0TDI Quattro:
Options:
Old 29th January 2017, 06:32 PM
Turbo Tony's Avatar
You realise, you're now going to have to post a how-to guide for removing and refitting the armrests, right?!
2008 Audi S8
Old 29th January 2017, 06:35 PM
ScottD3's Avatar
Nahhhhh.
[center]
06 3.0TDI Quattro:
Options:
Old 30th January 2017, 10:08 AM
ScottD3's Avatar
Got an email back from SGS.
Thank you for your enquiry with SGS Engineering. This unit is a damper rather than a gas strut, we do not have the facility to repair or replace these units so unfortunately we will not be able to proceed with this enquiry.
Thank you for trying SGS Engineering, please do not hesitate to contact us should you have any future enquiries.
Kind regards,
SGS Engineering
Bugger!!
If anyone does find a damper that works or away to replace these.
To strip the arm rest down is a bit of bit of paint but doable.
Just remember how it goes back.
You also need to push out the retaining pins that holds the main ally body together to be able to strip the strut out.
I will do a guide next time I strip them down.
[center]
06 3.0TDI Quattro:
Options:
Old 30th January 2017, 12:48 PM
RC Cars have similar dampers, but probably not worth the hassle of changing the ends or fashioning adapters.. Does it have a Nm rating on it? I would expect 200-400Nm. I think the damper just acts at the top of the armrest travel to catch it before it bounces off the endstop and then hold it wide open somewhat - once closing it doesn't seem to have any effect. What do other think?
