You could also diagnose it with a volt meter. If you put the meter across the motor first, that'll rule in/out a motor problem. Running normally, I'd expect to see a voltage that changes with fan speed. When the fault occurs (ie fan not running when it should be), 12 volts would suggest a motor fault and 0 volts a controller/power fault.
If the first test suggest a controller/power fault, attach the meter's ground to a permanent ground connection (leaving the positive wire on the motor's supply connection). Running normally, you should have 12 volts. When the fault occurs if you still have 12 volts the problem is with the 'hedgehog' (or associated connections), if you have 0 volts, the fault it with the supply.
Thanks Mark, I like the logic, but it means hacking into cables or connectors to get readings and it's all weatherproof connectors in that area, so I'll try the "plug and play" option first.
I'm guessing that the thin wires running off the thick power feeds near the beige connector are probably to measure the voltages as part of the HVAC control system and the extra yellow/red wire is a control signal to the "hedgehog". I would presume it's fins are purely for cooling what is effectively a variable resistive load.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 3rd August 2017 at 02:01 PM. |
That would be my guess too. The yellow/red is definitely a control wire. If the controller is a simple high-power bipolar transistor, you'll probably see a voltage on that wire that varies with fan speed (probably 0-5 volts). There does appear to be some feedback/sensing connections too which may account for the remaining thin wires.
