Old 5th November 2018, 09:10 PM
Originally Posted by Nognar View Post
Interestingly enough if I turned the HVAC off for a couple of minutes with the car running then turned it on again I got a huge initial blast of heat from it so there is heat in the system ok.
It was this comment that made me wonder what was going on.
What happens if you let it warm up properly in that way then turn the ignition off and try the "Rest" function?
e.g. can you hear the pump running? You may need to override the fan speed down to minimum to check that or even go under the bonnet to listen carefully.
