Old 20th July 2018, 10:01 PM
Return at the back (apologies for the focus ). I need to make another support halfway along this when I build the exhaust support bracket. On the next ones I might actually use the C5 return hardline at this point and join the hose where the pump union is.
Using C5 pipes is what I was thinking.
Just to think when I was buying new radiator for C5 a year or 2 ago everybody in 2 different shops was telling me there is no radiator with integrated gearbox cooler for manual boxes, just auto. I think cooler is only for cars with 180 HP??, could be wrong. Anyway after having 5 wrong radiators supplied in 2 different shops even supplying reg number and Audi part number ( no gearbox cooler, pipes in wrong locations and wrong diameter pipes) I finally gave up and ordered one from Germany, cheaper (£80) , right stuff and arrived in 3 days
Old 20th July 2018, 10:17 PM
Yes, from the 180hp 2.5TDI, and also the 2.7TT as well I think. They won't work directly in a D2 V8 since the C5 has them in the radiator on the driver's side and the D2 is on the passenger side, but I can use most of the return hard-line to save having a long run of hose
Old 21st July 2018, 07:35 PM
The engine and gearbox are ready so on to the internal bits.
Don't need this any more
Space for the new shifter
A6 shift lever on a custom bracket. This bracket is 'knife & forked' from flat plate and angle section. The production run will be CNC'd and folded.
The other half of the shift levers. Autofocus on the Oneplus One sucks btw.
Fitted in the tunnel with the protective boot (this is an adapted A6 boot btw since the D2 one of course is NLA)
Shifter in place
Shift rods from the tunnel
They attach to these
I split the shifter rods using some custom turned adapters so that they can be split at the back of the gearbox from under the car. This means you don't have to pull the centre console out to remove the engine. I'll show how this goes together when the engine & box go back in.
On to the pedals.
Conveniently, whoever designed the firewall on the D2 didn't get the message there wasn't going to be a manual RHD version, so they put a place for the clutch hose to go through the sheet metal This is pretty much a mirror image of where it is on the LHD models.
Hole drilled and a pull-through, er, pulled through
This is where the hose will come through the sound deadening.
and this is where it all went a bit Pete Tong. I bled the clutch master cylinder on the bench before fitting it to the car, and while I was doing so discovered that the seals had failed I think operating it dry while I've been designing the pedal has trashed the internals and so it can't create enough pressure to operate the clutch fork. I can't get a new one until Tuesday.
Bugger
Mike's Murple is in on Monday for an engine-out service so the swap has to go on hold while we do that. Its unlikely I'll get any time to finish it off before Germany now.
So close...
ID:	19830   Click image for larger version
ID:	19831   Click image for larger version
ID:	19832   Click image for larger version
ID:	19833   Click image for larger version
ID:	19834   Click image for larger version
ID:	19835   Click image for larger version
ID:	19836   Click image for larger version
ID:	19837   Click image for larger version
ID:	19838   Click image for larger version
Old 18th November 2018, 06:12 PM
This is nearly complete so I thought I ought to update the thread
I sourced a replacement clutch master cylinder and bled the complete system on the bench, then removed the slave and capped off the hoses. Put everything back in the car, reattached the slave and bled it again. This time it worked with a nice solid pedal.
Hose routing.
Clutch switch for the cruise control
Slave cylinder. I re-used some heat-shielding from the wiring harness as the hose runs a bit close to the downpipe.
Driveshaft - new v old
Engine and box going back in
Loads more room in here now
The clutch slave is a total **** to get to with the engine in! Much more so than in the A4 or A6, simply because the superstructure of the D2 is so much more bulky.
After a successful test drive I started putting the interior back together. I've lost a bunch of pics, but I printed an adapter piece to fit an A6 gearstick gaiter in to the D2 console trim which looks like this:
Installed it looks like this:
I also removed the tiptronic steering wheel and replaced it with a manual version.
ID:	20446   Click image for larger version
ID:	20447   Click image for larger version
ID:	20448   Click image for larger version
ID:	20449   Click image for larger version
ID:	20450   Click image for larger version
ID:	20451   Click image for larger version
ID:	20452   Click image for larger version
ID:	20453   Click image for larger version
ID:	20454   Click image for larger version
Old 18th November 2018, 09:25 PM
27litres's Avatar
27litres 27litres is offline
Wow!
Looks like it grew there Michaela!
Nice job!
I like the detail with the removal of the tiptronic steering wheel!
Your little details printed up on the 3D printer add to the fit and finish too.
Marty
____________________
2002 Audi S8 - Project
Family:
2009 Volvo XC90 V8 R Design
Sold:
1997 Audi A4
Old 19th November 2018, 07:54 AM
Awesome job MJ - this is a triumph of skill and care
Old 19th November 2018, 08:31 AM
RICKY D's Avatar
RICKY D RICKY D is offline
Huge respect MJ
Looks so good!.....when are you taking orders?
Old 19th November 2018, 08:34 AM
Awesome. Truly awesome.
Old 19th November 2018, 11:08 AM
Regulus Regulus is offline
That is some piece of craftsmanship
I sincerely hope you feel that all the work you have invested, to be able to do the conversion, has been worth the time and effort.
In any case, you do prove time and time again - that hard work and commitment beats anything the schools can offer in terms of education and skill acquirement!
You should have an apprentice who wish to learn the trade the old fashion way
Johannes
_________
A8 32V engine
Jeep Grand Cherokee -98
Old 19th November 2018, 12:20 PM
Truly impressive. Not just the build but also the way you've completed those important cosmetic details
