Old 12th March 2019, 02:02 AM
CrozA8's Avatar
CrozA8 CrozA8 is offline
Default Rear Lid Lining Removal
Gents,
Having trouble locating the two fasteners that hold the grip moulding into the boot liner. I've followed the workshop manual for general body repairs but cant find/uncover these two:-
7 - Bolt, 2 Nm
❑ 2x per moulded recess.
Any help anyone??
2006 A8 4.2 Ltr Silver Green 20" Factory Alloys
Old 12th March 2019, 07:16 AM
Originally Posted by CrozA8 View Post
Gents,
7 - Bolt, 2 Nm
Any help anyone??
Page 269 of THIS DOCUMENT should help you - most docs are in the common faults thread of each seection (D2/D3/D4 etc) under "TECH DUMP" which is stickied at the top
Old 12th March 2019, 10:44 AM
These screws are difficult to see. (They are items Nš 7 in the diagram and fit through item Nš 8 into item Nš 14.)
I lean backwards into the open boot.
Then look upwards and into the grip.
Using a strong torch/light you will see the recessed screws. They might be covered with plastic pieces to hide them.
The crosspoint head of the screwdriver in the toolbox will fit them.
I find it more difficult to get the so & so's back in.
If you open the document that Neil suggested in a PDF viewer you might find that the actual page is "279"
Old 13th March 2019, 07:18 AM
CrozA8's Avatar
Yes had that document open but still could not find the damn things.
Thanks
Chris
Old 13th March 2019, 07:24 AM
CrozA8's Avatar
OK TC4332, thanks for your direction. I knew there was something I was not seeing and it appears to be the camoed screw heads. I too did sit in the boot but could not see them.
Will attempt the same with a 1000 watt light source.
Thankyou for your assistance to both gentlemen above.
Chris
