Old 14th October 2010, 12:23 PM
Nick1
Guest
Posts: n/a
Default bad vibration
dont no if this is the right section to put this in but here goes
when i put the car in to drive i get a realy bad vibration coming from all over the centre console where the gear lever is,with my foot pressing the brake,if i put it into neutral it goes off all while standing still,i can also feel it while traveling when i accelerate but not as bad any ideas guys
Old 14th October 2010, 03:04 PM
Has the engine management light come on?
Can you do a VCDS scan?
Old 14th October 2010, 07:22 PM
Nick1
Guest
Posts: n/a
yer light is on thought it was afaulty cat it seems to get worse when i press the brake pedal
Old 14th October 2010, 09:36 PM
I'm thinking faulty ABS. Can you feel the vibration through the brake peddle?
Old 15th October 2010, 10:24 PM
Torque converter??
Old 16th October 2010, 01:14 PM
Nick1
Guest
Posts: n/a
yep i can feel it through the brake pedal any ideas
Old 16th October 2010, 03:50 PM
If the ABS control module is getting duff information from the speed sensors at the wheels it may be operating the ABS. Without looking I'm only surmising that what your feeling is the pulsing of the brakes because the ABS is operating. Can you do a Vagcom scan? An output test on the ABS module would help.
If not try removing the ABS sensors and giving them a good clean.
I could of course be miles out as..................................
Old 17th October 2010, 10:09 AM
I'd have the gearbox/engine mounts checked as well...
Old 17th October 2010, 12:37 PM
I agree with psyche. Does the gearbox output shaft seal leak and how high is the mileage? Could even be wear in the gearbox main shaft bearings or propshaft joints but that would have got worse more gradually. Did it start suddenly or grow?
Old 18th October 2010, 06:03 AM
Nick1
Guest
Posts: n/a
had a recon on the gearbox 12 months ago so iam hoping it wouldnt go that quickly,funny thing happened last night the esp light kept flickering on and off does this indicate an abs fault,and were would i find the abs sensors if so to clean them cheers nick
