Old 16th July 2020, 11:35 PM
Audifan Audifan is offline
Thanks again MikkiJayne but now I'm confused. How is the flat bar mounted as there is no way it will mount flat to the upright as see in this picture Or is the opposite side of the upright flat that's not visible in this picture?
Old 17th July 2020, 12:26 AM
Your picture is from different car. Flat bar was on S8 with Brembo brakes. Different brakes and uprights on S8 compared to A8
Old 17th July 2020, 07:54 AM
Correct ^
The RS4 setup is on an S8 Brembo upright whereas I am showing the Porsche 18z with the A8 HP2 upright.
Old 17th July 2020, 11:30 PM
Thanks for the clarification as that makes more sense.
Old 20th July 2020, 01:24 AM
27litres's Avatar
27litres 27litres is offline
the RS6 had 19s.
In the land of Audifan, the C5 RS6 had 18's stock. So assuming they didn't change the brakes, they will fit under 18" wheels.
Originally Posted by Stromaluski View Post
If you purely want your car to stop better, you'd actually be WAY better off buying better tires. Your car's limit in how quickly it can stop is purely a function of how much your tires can grip the road.
Using a more simplified example, here's something you can think about. If you can lock up the brakes on your car (assuming the car doesn't have ABS), then having even more clamping force will provide zero benefit at all. You can't make the wheels stop any more if they're already stopped. The same idea would apply even to a car with ABS. The limit of how fast you can slow down is an issue of how much grip your tires can withstand before they lock up on the road surface. Bigger brakes, more clamping force, etc won't change that at all.
Basically a long post to simply say if you want to increase your braking capability... buy better tires.
I like your thinking, but one of the biggest factors for increasing disc size is heat dissipation.
You're right in tyres being a critical factor in how efficient your braking is, and the leverage action of larger discs and calipers, but the larger size disc also provides a critical benefit in heat dissipation.
You alluded to it a bit anyway, so I'm sure you're aware of most of this, but brakes are all about energy management.
When the car is at speed, it has a large amount of momentum which is Potential Energy.
In order to slow the car, you need to convert that energy into another form (conservation of energy).
Cars use brakes to convert all this Potential Energy into Kinetic Energy, in the form of heat.
That heat energy then needs to be added to the surrounding environment through equilibrium as efficiently as possible.
A measure of how effective the brakes are, is how effectively they can shed the heat, which is a measure of exposed surface area.
So:
Ventilated discs are better than solid discs.
Bigger discs are better than smaller discs.
Larger pads are better than smaller pads (within disc coverage limits), and larger/multi piston calipers allow for larger pads and better control.
Then there's the engineering compromises of unsprung mass, physical wheel size, metalurgy, cost etc
But as you said, none of this is any good if your tyres lose grip!
Marty
____________________
2002 Audi S8 - Project
Family:
2009 Volvo XC90 V8 R Design
Sold:
1997 Audi A4
Old 20th July 2020, 09:13 AM
Larger pads you say...
Porsche / Q7 18z pad vs S8 Brembo! These things are huge Tbh I should have figured that out from the size of the caliper but it didn't really register until I had them in my hand.
Btw, cheapest brake pads on the market for a Porsche Cayenne / Audi Q7? £26
For reference, this is the 18z caliper on an S8 Brembo upright - no way this will work:
This is the 18z caliper on the S8 345mm disc - also not going to work
However, the pads fit the D3 360mm disc perfectly. The only challenge then is a 4mm offset in the mounting holes:
I think this might be possible to solve by boring out both the caliper and the upright an additional 1mm and creating an offset bushing to take an M12 12.9 bolt, something like this:
I'd have a plain one in the caliper, and the threaded one in the upright, both knurled slightly to grip the aluminium and not rotate, then they'd hold everything in place nicely. I did this many years ago to get Nissan Skyline 4-pots caliper on my Corrado However with this setup, its a compromise between using M12 12.9 hardware vs OE M14 10.9 hardware or removing sufficient material from the caliper to get M14 hardware in without losing strength.
ID:	23640   Click image for larger version
ID:	23641   Click image for larger version
ID:	23642   Click image for larger version
ID:	23643   Click image for larger version
ID:	23644   Click image for larger version
Name:	offset bushing.JPG
Old 20th July 2020, 01:34 PM
Stromaluski's Avatar
So:
Agree with all of this.
-Andrew
1967 Bus
1980 Rabbit Pickup
1992 Corrado
2001 S8
2010 Jetta TDI Cup Edition
Old 20th July 2020, 05:13 PM
Lots of great information. Thanks for sharing.
Old 21st July 2020, 09:50 PM
I've gave it some thought and decided to go with C5 RS6 front caliper and discs since it'll be easier for me to mount the calipers. And for the rears I'm going to go with C5 RS6 rear brakes instead of trying to fit 4 piston calipers from a Boxster and custom install a hydraulic e-brake or try to custom install an additional mechanical parking brake setup.
This upgrade is something that I will eventually do and as of right now it looks like I won't be able to get around to piecing it together till next year. So I'm just looking to get as much information about it now.
Old 22nd July 2020, 11:19 AM
The only issues you will have with the C5 RS6 rears is the Handbrake cable. You will need the cables from a LWB D2 A8. They are pretty rare. Maybe Audi heritage?
