#81
60 times normal speed, I think that's acceptable
#82
Impressive! ![]()
Mark ------------------------------------------------------ 2002 FE S8 Ebony Black Pearl ------------------------------------------------------ ------------------------------------------------------ Cars Owned: The Tesla Era: 2020 Model S Performance Ludicrous+ (present) (Black, with all black premium interior and carbon fibre décor, 21" sonic carbon twin turbine wheels and FSD capability) The Audi Era: '97 A8 4.2 (Ming Blue) --> '96 A8 4.2 QS (Dark Green) --> '02 FE S8 (present) The Citroen Era: '84 BX 1.6 RS --> '89 BX 1.9 DTR Turbo --> '94 XM 2.0L Turbo --> '96 XM 2.0L Turbo Exclusive --> '00 Xantia Activa 2.0L Turbo The Banger Era: '76 1.2L Lada VAZ-2101 (Ruski Fiat 124) --> '80 1.7L Morris Ital HL, finished in Ermine White and Rust Last edited by moltuae; 9th January 2021 at 02:34 PM. |
#83
Stupid PS cooler! That's not going back on
![]() No video today as I forgot to take the Gopro mount so back to pictures. It's had the front level sensor and arm fitted at some point recently. Its the wrong arm, obviously (FE version) ![]() Drain grommets are removed as usual and just sitting next to the ABS pump, obviously ![]() Cut the heads off the lower rear arm bolts, rather than cutting holes in the floor ![]() Tie rods came out, which is nice. Usually on a car in this state they are seized solid. Everything simple disconnected, just held in by the top plate Remove as an assembly - I'll break this down separately, although not much of it is going back on. Bare, and now I can get to the PS pipes. And clean everything, obviously. Grot everywhere. Definitely the worst so far It looks like the gearbox was dragged around on its sump when it went away to, or came back from, refurb. The pan is bent and distorted. Shame to treat £3K of refurbished gearbox like this ![]() Oil is leaking from everywhere Everything in here is either seized, snapped, or loose ![]() Snapped rivnuts are no big deal as they are easily replaced This earth point is going to be a real stinker to drill out, upside down ![]() The starter cable stud was pre-snapped. This'll get replaced by a rivnut. The one front panel bolt which snapped The heat shields are mashed up from the engine and / or gearbox being removed previously. I'll replace these studs. The servotronic solenoid is looking very crusty, and the green verdigris hints as to why it is intermittent. The rack will need to come out to replace this, which is a shame as I didn't disconnect the steering column before putting the car on the lift ![]() More grot from oil leaks Its going to take some cleaning, this one... |
#84
It looks like you have your work cut out on this one!
I have a real soft spot for a Murple so I’m looking forward to seeing this all clean and back to its former glory.
2002 S8 - Irish Green Pearl. Cat N (saved by the D2 Doctor ![]() 1988 E30 Coupe - Royalblau Metallic 2003 S4 Avant - Light Silver Mettalic 2016 S5 Coupe Black Edition - Glacier White |
#85
I've come to the realisation that it's so much easier to take the whole radiator support off the car for access. This video confirmed it. When I did my timing belt last year, it was such a faf to edge myself into the front of the car with the support leaning off to the side because i kept the aircon radiator bolted to it... Not to mention it took me two days to do what Michaela does in a few hours!
Cheers Marty ____________________ Current: 2001 Audi S8 - Brilliant Black with Black interior, C5 RS6 rims (whenever I actually put them on...), Solar Sunroof, Tinted side and rear glass, RNS-D, Grom, Bose, clunky old phone in arm rest! 2002 Audi S8 - Project Replacement head coming arrived ![]() Silver with Black interior. All features as the '01, with the 'S' mode auto shifter. Dodgey rear tint (need to find a way to get rid of that). Family: 2009 Volvo XC90 V8 R Design - has a louder more obnoxious exhaust than the S8, sounds great! Love this thing - Q7 was double the price, and certainly not double the car! Sold: 1997 Audi A4 - Hamilton's Club Sport, Achat Grey (will miss the old girl) |
#86
Glad to see work starting back up on this!
-Andrew 1967 Bus 1980 Rabbit Pickup 1992 Corrado 2001 S8 2010 Jetta TDI Cup Edition |
#87
Andy. Current cars: BMW i4 M-Sport Peugeot 207 (the sons) Triumph Daytona 675 (2017 reg) =========================== Gone but not forgotten Ford Focus ST-2 Mk3 (the wifes) (stolen Oct 2023) 1972 T2 Bay Window Camper (Slow) Audi TT Mk1 225 - now with coil-overs and a 7inch touchscreen infotainment centre 2003 A8 Sport 4.2 (with ACC & LPG) (Feed up with all the issues so passed it on to a forum member) 2000 A8 FL QS 4.2 (with RNS-E - Nice ![]() |
#88
In a case like this where everything was seized then its a struggle to get it apart the first time, but once it's all dealt with it'll be simple next time. The front end comes off my grey one in about ten minutes - the worst bit of the job is disconnecting the PS cooler which is annoying and messy but as I hinted earlier, thats not going back on this one as I will redesign it not to go through the front panel. In later models Audi changed it to connect from underneath so it can swing out of the way, so I shall do the same. The AC rad just swings out of the way too. With the front panel on, its harder to get tools straight on to things like the water pump and crank pulley bolts, where finesse is essential. If you round off one of those then the front is coming off anyway to fix it, so better to just remove it at the start ![]() |
#89
Some 'interesting' discoveries today, including two new contenders for the worst D2 bodge of all time. The guy who maintained this had a pathological inability to do anything properly.
There are two types of bolts holding the subframe to the car - different front to back. The left hand bracket has a front bolt in it, the right hand bracket has the correct rear bolt. He couldn't even get these right. Oil all over the cats. No wonder it smoked like a high school disco! Engine out The crud is half an inch deep on the subframe, but at least it's not rusted out I couldn't get the right hand shaft off as five of the six bolts were so tight they broke a spline key trying to undo them. The sixth of course was finger-tight. I left it and figured I'd get the impact wrench on it instead - no bueno with that as it just shredded another spline tool ![]() I thought I'd try some heat on the bolt heads. That didn't go well as I was instantly rewarded with a small fireball when all the oil ignited! Possibly I should have cleaned it first ![]() ![]() This worked in the end, without catching fire or breaking anything A big pile of bits! The cretin hadn't bothered refitting the thermal protection on the wiring harness when he replaced the engine so the sleeving is a tad crispy here and just crumbled apart. I'll fix that later. Are you sitting comfortably? Sure? . . . . . . . . . . . . . Why is the gearbox oil the wrong colour? ![]() Because it's hypoid diff oil ![]() ![]() Just... what? This gearbox was rebuilt 20K miles ago, and the idiot refilled it with diff oil, not ATF. I guess here endeth the discussion about these gearboxes being picky about what oil they run on ![]() Time to lift the engine and box off the subframe, except the lifting eye is missing. No matter. I have a spare. Once the subframe was moved out of the way I removed the engine mounts to put it on the separating machine, and wondered why one of the bolts was finger tight. Oh look. He cross threaded an engine mount bolt, stripped the thread and broke the block ![]() Nothing is surprising me by this point. I'll get a better look at this when the engine is on the stand. Its likely it can be helicoiled. This bolt, along with many others is a; mangled, and b; in the wrong place. After spending 5 minutes carefully cleaning it and contriving an allen key to get it out, I discovered it was only finger-tight. The bolt which should go here is missing completely, and there's a hole underneath where this bolt used to be. Finally on the separating machine There is a silver lining to all this, which is that this is my car which I bought for scrap money, and not one of your cars which you had thought was being maintained properly! I would not want to have had this conversation with any of you guys! ![]() Its all fixable, I have parts, I'll just crack on with it and it'll be glorious again ![]() ![]() Last edited by MikkiJayne; 10th January 2021 at 08:21 PM. |
#90
Wow, how can these people even go to bed at night knowing they've messed something up this bad? I could not live with myself if I did that!
